I like the window tint. How many inches is the strip on the windshield? and does it effect your view??
Its down to the AS1 line and definitely helps keep the glare down.
The installer let me look at it when they were putting it on, sit in the truck to make sure it was where i wanted it. They had brought it all the way down to the lower part of the box behind the rearview mirror and that was WAY too low and obstructed my view.
Took some pictures this morning.
Changed my foglight bulbs with LED..
Can't wait til night time to see it..
Also, took some pics of my in grille Led-8 DRL
Lights look Sweet, can you share the info where you got them and how you mounted / powered them, I would definitely like to do this to mine! Now have the Bowtie wrapped white!!
Edited by Chevyrcg
The led-8 DRL is here: http://www.ebay.com/itm/NEW-PHILIPS-DRL-LED-DAYLIGHT8-DAYTIME-RUNNING-LIGHTS-12-VOLT-1-PAIR-DAYLIGHT-8-/301080184142?pt=Motors_Car_Truck_Parts_Accessories&hash=item4619c7054e&vxp=mtr
Mounting is super easy.. Power is connect to Battery .Come with 3 wires + - and parking light wire, but it's control by it own control box so you don't have to worry about it being on all the time. It's on off with the ignition. Also you need to tap 1 wire to the parking light so it will dim when the parking lights is turn on... when the parking lights is off, the Led will go back to the super bright mode as you can see in those pictures..
Edited by block8head
Right on man… Thanks !
You're welcome my fellow Masshole .LOL
Which fog bulbs are those?
Block8head, do you have an untinted rear window? I wish mine was untinted now that i have the camper top on my truck.
It's factory tinted ,but not that dark.. I might tint them in the future..
A.R.E. Z Series with the Yakima roof system, AMP Research Power Steps, 20% window tint side windows and top strip of windshield.
Up next is a leveling kit.
i have the same z series shell luv it this is my second one.had one on my ford f-150 is your lock power or work with your remote? ...
Sure is. I also had the place install a pop lock for the tailgate lock. Love it.
Only option I didn't get which I wish I had was the Light Prop Switch so the lights would come on when the rear glass opens. Going to see if they can install one for me when I get my leveling kit installed.
http://www.4are.com/product/brochures/ARE_LED_Light_Options.pdf
Edited by PMD G8
