Installed Supersprings to add some lift and increase payload to around 3000lbs.
Tapatalk via Moto X
  • Like 5
I ordered a set of Cooper ST Maxx 305/60-18 tires for my truck today. Pricey, but what the heck. The Fuel Full Blown wheels I want are on backorder for 16 weeks. I may mount these on the stock wheels.
discovererstmaxx.png?width=400&height=56
Good looking tire. And I must say. When I see your posts and your profile picture I imagine a very sophisticated dog just typing with this look like 'yea, I'm a dog. Is there a problem?'
Yeah my dogs are living the high life at the "dog spa". My wife and I are the hired help and wait on them constantly.
Edited by spurshot
  • Like 3
I saw where Cooper has these in a 35x12.50 20 the other day now and am seriously debating replacing the Pro Comp Xtreme MT2's with them. I just have to convince the wife that I need a new set of tires after only 8K miles.
Something unfortunate could just randomly happen to a current tire! Or they could all just randomly get a few nails in them coincidently
Ha! If I can get here to take a ride with me for about 5 hrs she will make me get rid of them.
I took mine in to get an oil change. I mentioned how these do not light up, thinking they wouldn't know anything about it (small dealership). Anyway, the manager didn't have a clue, but said he'd talk to the guy in Service to see what they can do. Well he called me today, said there was a long note put out by Chevy that they wont fix it, and basically to bad.
I guess its not a big deal, but I wish they would have told me all this prior to me buying it. O'well..
I took mine I n for a recall and mentioned to the dealership that I had been reading about how the lights were supposed to be blue and lots of people were taking them in to get fixed. He said he'd check into it and then he just fixed it. No questions asked.
Edited by Bugler
Had to go to the dealer, they lost my 2nd set of keys cause my truck came from another dealer cause they didn't have the 1 I wanted..so I got 2 more keys and my Second remote and a car wash there. You guys ok with letting your trucks/car go threw those Carwashes. I've always thought they f up the paint ... I only go threw them if there brushless . But I hate the idea my key and other remote is out there somewhere:(
Installed a GateKeeper to hopefully keep my tailgate where it is.
Also installed Timbrens on the rear. The ride unloaded feels much better to me, less lean on corners and not so much of a floaty feeling on bumps. I'll be testing loaded performance tomorrow...
I guess I'm a day late, I got my RCX 2.5 level on yesterday. Too much rake with the 2" block I might go back to the factory 1".
Well that's awesome for you, but really pathetic Chevy wont just fix this across the board and stop trying to fight it. Humm...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
