2014 High Country Wheels
d6007
It's not like GM made those tires. However GM engineers can design vehicles and wheels to work together...
Sent from my SCH-I535 using Tapatalk 2
  • Replies 65
It's not like GM made those tires. However GM engineers can design vehicles and wheels to work together... Sent from my SCH-I535 using Tapatalk 2
No company in their right mind would deliberately install defective tires on their new vehicles, especially in this price range. But going with the lowest bidder sometimes backfires.
  • 3 weeks later...
People who say "ride is compromised with 22's and that 22's don't have any side wall" must be either OLD and fragile, or uneducated. It seriously drives me nuts, if you were blind folded and told to drive different trucks one with 20's and one with 22's the average person wouldn't be able to tell the difference!! Have you ever seen the factory tires on a BMW?!! Older 3 Series BMW's with the 20" option came with 245/30/20 and 295/25/20.....
:rant:
I wouldn't say the ride is compromised but their is a difference. You could blind fold me and I could tell you easily which truck has the bigger rims. Comparing large rims on a truck to rims on a BMW is comparing apples to oranges. Maybe because some of us must be "old" we have a better feeling for our trucks and can tell the difference. As for as being "uneducated" common physics of a tire tells you if you go with a smaller sidewall it will change the ride quality. Their are so many other factors to consider as well. The load rating on the different tires. The increase weight of the larger rims and tires. They all affect the ride and handling qualities. Some people may not notice, and for some people it is acceptable. And I'm one of the "uneducated" ones.
High Country wheels are gone, picked up these Chevy 22's yesterday. I think I'm going to ditch the toolbox and go with a tonneau cover, just gotta decide which one....
Truxedo tonneau trax - comes with 8 tie down loops that lock into the mounting rails and are adjustable fore and aft as you need them to move. Lifetime Guarantee on everything including the cloth!
Just look it up you can get any kind of tire you desire for the 22 even off road. Just though I help you all out.
    HWN808
    HWN808
  • Who's Online   2 Members, 1 Anonymous, 1,043 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
