Add me as the latest member of the no start club. It has happened the last 4 days but I have been able to get it to catch. This morning it was -9 and it wouldn't go.
tell your dealer to call gm tach, and they will give your tech a different pt# for a different
starter. i posted the new starter # and picture a few weeks ago, no problems since the swap.
i work for a chevy dealer and i was just as pissed off as any of you guys, but this fix works !!
DO NOT ORDER THE STARTER LISTED IN THE PARTS CATALOG !! you will get the same
thing as what you have now. good luck with it. ray
A tad unsettling considered our entire trucks are built in Mexico haha
My '06 Silverado and '09 Impala are both built in Canada. No starter problem with either one to date. Nothing wrong yet with the starter on my 2013 Sonic built in the US either.
I bought my brand new Silverado a week ago and it hasn't started two out of the six days that I have had it. I took it to the local dealership for them to maintenance it and since it has warmed up here in Iowa in the last couple of days they are saying they cant fix anything on it. The lady at the dealership gave me a print out off of GM's site showing that they are aware of a engine complications in ambient temperatures and that they are replacing the starter in the trucks, but for some reason they will not fix my vehicle. For the price I paid and considering this is "the truck of the year" I expect it to start at ALL times regardless if it is -25 or 10 outside .This is the second truck I have had problems with in the last six months, I had to have the engine rebuilt on my 2011 Silverado due to the AFM. I'm not having any luck with these trucks at all!
The dealer told me today that they needed to order a starter for my 2014 and I asked for the part number.they ordered and they told me 12655055 (thanks Maliburay55).
Bad news is they wont get the starter until middle of next week. Good news is they sent me home in a 2014 Silverado as a loaner and apologized for the inconvenience.
you need to tell them to have there tech to call GM tech line, there is a problem....
the mexican starters !!!! they gave me a completly different part # for a starter
to corect the problem ! take this to your dealer.... here is the new starter pt # 12655055
dont let them order another one from the parts catalog or you will get the same thing.
i work for a chevy dealer, i have a 2014 silverado that had the same problem.
i'm the parts manager for cambe chevrolet. the new starter has worked every time.
good luck with yours.
Maliburay55, thanks for that info!
I'm having the same issue as being described by the OP and others. Dealer still has my truck overnight to do a cold start in the morning. I'm hoping it fails just so they can continue diagnosing and don't give me back a bad truck. If it fails and they continue to work on it, I'll recommend they replace with this part number. Thanks!
Here's my thread if interested:
http://www.gm-trucks.com/forums/topic/159012-not-starting-after-only-148-miles/
Good luck HaperZ71 it was not cold enough when they checked my truck so i got mine back with a bad starter.
This is what the dealer gave me. It was to warm to start now so i got screwed no fix. I did call the Chevy customer support number and open a case file. They had not heard anything about the trucks not starting when its cold. post-128805-0-34735600-1394203604_thumb.jpgpost-128805-0-86239100-1394203617_thumb.jpg
Edited by luke3434
I got my truck back yesterday too. It started no problem for the dealer. They reprogrammed the BCU and gave the truck back to me.
This is what the dealer gave me. It was to warm to start now so i got screwed no fix. I did call the Chevy customer support number and open a case file. They had not heard anything about the trucks not starting when its cold. attachicon.gif20140307_082400.jpgattachicon.gif20140307_082418.jpg
I would call them on that as BS! I saw the same PIE paper as you linked when I had my truck in at the dealer. Sounds like their customer service is either not informed or just lazy. Good luck.
check my posts for the updated starter # there is a non public S.I. buliten dealers cant see
unless they have there service tech call in for assistance.
this is the starter we ordered for my truck. new starter pt # 12655055
If they told you that,they lied and you should tell them that and take your business elsewhere.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
