Who's got the most money in aftermarket stuff on the 14
White14
I have enough money in mines. Im done spending for a while. I started out with a SLT with every option so I didn't need much inside.
That house cant be in Bakersfield
  • Replies 85
Still no pictures......
Sent from my DROID RAZR HD
Truck is gonna look good. But
$1,000 body lift? And $8,000 in wheels and tires. I ran 24's on37's before. The tires were like $700 a peice. Your telling us that you paid $8,000 for 4 rims and 4 tires? That's like $1,000 per wheel and $1,000 per tire.
Sent from my iPhone 5 using Tapatalk
Go price a set of american force wheels and toyo mt and get back with me. Paid $7256 from 4 wheel parts. Then I had to get all new wheel sensors and 6 sets of wheel locks. And $2k for gears lol there actually more than that call around for 4:56 gears for a 2014 silverado and watch what happens
I looked at American force wheels. For a 20x9 they were almost $1100 each!!!!!!!!!!!!!!!! I'm too rough on wheels to pay that much for them. $2K for a gear swap is normal. You have to change two gear sets. OP is not lying.
Wow then those 24's were prob an insane price.
I spent $70 on having my front two windows tinted. Does that count? lol.
Man, these trucks are $55k. I would find other things to spend $25k on like a boat, European trip or a college savings fund. I know to each their own, but wow, that's a lot of green.
Bottom line...if you have the money and find enjoyment in tricking out your ride, have at it.
photo 3
photo 2
No you're not being disrespectful at all, I believe I'm correct. In the future I'll either be more forgiving in my judgements or censor topics. Thanks for the option provided.
Sent from my VS840 4G using Tapatalk
I wanna see some audio pics as well. What all do you have? I've got about $6k in a JL audio set up in mine too. JL audio makes some mighty fine stuff
Sent from my Galaxy S3 using Tapatalk
That looks great! Random question: how much does each of those tires/wheels weigh? Gotta be rough on there...
Sent from my LG-D800 using Tapatalk
WOW, I guess I was wrong when I told my son when he bought the Ford with the Tuscany package that I could get it done cheaper in the aftermarket. Nice thou.
My gear swap is 1600$. Lift from BDS was 1300$. Wheels and tires where 2500. I would say you have everyone beat in the money you spent. I'm only at 6500$ spent on my truck. Geez man. May spend another 2-3k more that's it
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
