Gear Change 9.5" 12 bolt
CAtaylor
  • Replies 131
Let me know if you want to sell the 3.42 when you put your new gears in.
I sell to you if you want them. Just waiting to get them in.
Interested to see how this turns out. I know visually we wont be able to tell the difference. But I wonder what all needs to be done to adjust the computer for the speedo, traction control and stabilitrak
Its as simple as erasing the 3.42 and typing in 4.56 then hitting the upload to ECU button. It would take longer to get my laptop out of the case than to make the change.
Good to know.
  • 3 weeks later...
Well the gears are finally getting installed, should have the truck back tomorrow. The only dilema i have now is do I correct the spedo with the hypertech calibrator that the dealership gave me with the truck or do I roll out with the new BB tune.
Use what you have already, if you aren't happy with it then by all means, tune that shit up and keep us posted.
Well S***! For some reason you remind me of my wife, Ha! Most of the time she gets to say "I Told You So" though, so i think that is the route i will go for now. Only issue is i have to deal with Hypertech to get the thing unlocked. It was installed on the truck while it was still on the lot. The service department did the fire recall when i bought it and overwrote the Hypertech programming and now it is locked and wont let me download the GM file because it already has my original in it. Maybe i can get that corrected tomorrow while they finish the truck up.
Scuhhhhreeeeewed... All the better reason to get a real tune now. Hypertechs suck anyway so....
For yours and her sake, I hope her and I look nothing alike.
Got ahold to Hypertech today and the reset the calibrator for me no questions asked. I will use this for a while just to make sure everything is all good after the install. Looks like it will be tomorrow before i get the truck back. They got delayed and didn't get it in the shop till around 10 this morning.
Well, they never got to the truck. Looks like it will be another week or so before the gears get put in. Back to work for a while.
I hear ya. I was kind of pissed actually but the guy is such a good guy i couldn't bring myself to be a butt about it. He was honoring a job he had done prior so i felt good about it.
I heard these trucks were dificult to put the gears in.. Is that true? I thought it was about blacklash or some alignment issue. Did you buy gears for a 14?
Ok, is it hard to replace the gears. No!
Is it hard to get it right? Yes,If you don't know what you are doing you will not get it right. There is more to it than draining the oil, dropping the cover and exchanging gears. You have pinion depth, lash, pinion preload (most people have no idea what that is, but most think they do). It can be frustrating the first couple times but once you get the hang of it it's not bad at all... Plus if you find a good gear company it can cut the installs in half. If you want to do it yourself, do your homework. If you take it to somebody else to donit.....do your homework! Lol
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 832 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
