Adding Interior Lighting? Fuse?
jdjuice
  • Replies 100
I didn't splice anything. I just stripped the tip of a 16 ga wire and pushed it in to the little square slot right alongside the grey wire, and then zip tied it secure
Ok thanks. I'll look into that instead. I am surprised there is not a fuse to just tap into.
  • 4 weeks later...
So I took a look at the lights around the visor and it looks to be an actual led bar and not some little bulb. I was hoping to make it brighter. Has anyone tried to upgrade those or replace them? Or that is not an option at all.
Sent from my SM-N900V using Tapatalk
  • 9 months later...
vu8yruja.jpgqy5a3azu.jpg all 8 attached to the same place. They look awesome.
Wicked Galaxy Note 3
Where did you run the wires for the passenger side steps? Love the look! Just wondering about wire and light longevity? Thanks for the help
I ran them to the cab under the carpet in the passengers feet there's a grommet, I made a super small hole and passed the wires to the drivers side under the carpet, connected to the dome light at the A pillar, thicker grey wire. The interior lights are still going great after 3 years, the outside I had to replace a few times now as I mess them up with my feet when I hang off the door or putting in my kid and I have to balance myself so I tuck my feet under there and they start to malfunction
Sent from my LG-H918 using Tapatalk
vu8yruja.jpgqy5a3azu.jpg all 8 attached to the same place. They look awesome. Wicked Galaxy Note 3
Any issues with the added load on this circuit? I know Led are small amp draw. But Im thinking about doing this to my new truck and that is probably twice what the stock dome Leds draw? Whats the fuse rated to etc? Thanks for the help!!
No issues at all.
Old thread i know. I was just wondering if you know what the Led type is? 3528 Or 5050? Appreciate the help thanks.
I have no idea, I just used some cheap Amazon leds
  • 3 weeks later...
I understand and will follow the steps. I do have a question?? Is there a way to connect and still have them turn on when unlocking the truck or when opening the doors while the dome light switch is activated. I like not having my entire cab light up but would like just the steps light up. ( Is my question making sense to anyone )
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
    • Prices on the hi-way are falling daily, $3.66- $3.71, Local has yet to drop, actually some are still going up, $3.87 and up
    • I finally got it to start. It was a mix of a few issues. The frame ground was in bad shape so I ran a new one and cleaned up the area to get a good connection then covered it in rust reformer then bed liner to keep it as clean as possible. The other ground I found that looked suspect was on the frame toward the back of the truck near the bed. I did the same. After pulling the fuse box out from the engine bay I found a couple of wires that looked like at some point mice may have got ahold of it. That was an easy fix. After that i was able to get control power and was able to trace down a few more connections going to the other fuse panels in the cab. After that it finally started up and runs. It sounds like an angry school bus which I can work with. No OBD2 codes, but I think since its set for a long time I should pull the turbo and get it rebuilt or swapped out, but for now im good to go. Thanks for all the advice. It got me on the right track.
