Tow Hook Surround Trim
I bought the same part, havent looked at it yet, can you remount the front plate holder without drilling any holes in it?
unfortunately not....i am going to leave it off for a while and hopefully not get pulled over haha
  • Replies 60
For the 2014 Silverado:
22944881 is the black filler piece with the holes for tow hooks
22944882 is the chrome (plastic) piece
I bought both of these pieces from an online retailer and they will not fit together.
I took them to the Chevy dealer's body shop and to a 3rd party body shop and both places could not get the chrome plate to fit into the new back plastic filler piece nor into my existing black plastic backing that the hooks fit through(not exactly sure what it is called).
I really want to replace my ugly gray with chrome but I have not been able to get one that fits.
I have actually purchased two of the chrome parts from different online dealers.
The clips on the chrome parts are too thick and will not slide in far enough to clip into place.
Do these online dealers have different parts than the local dealer?
They say oem parts and they come with an GM emblem on them and what looks like an oem sticker on the packing, but they will not fit.
I haven't bought one from the local dealer yet, but I would if I knew it would fit.
I post this in hopes someone has a solution.
Also, does anyone have a part number for the little metal clips that hold the chrome piece on each corner of the chrome plate and the center of the black filler piece to the bumper?
I lost one in all of this trial-n-fit fun I have had this last week.
I was thinking of cutting the little clips off and see if that would allow the chrome piece to fit into the back black filler piece.
Thanks Randall
Thanks Randall
i had the same problem trying to get these 2 pieces to fit together......i will say i just left both of them with the guys that did the install and they got them together.....i am going to call them again tomorrow to potentially have more work done so i will ask them how they did it
Found the part number for the clip. It is called a Valance clip GM#11562364.
Randall
Were you able to find out how they got them to bolt together?
I am thinking of cutting a few posts off the Chrome plate and using a dremmel tool to take a little off the rest of the tabs, at least until they will fit into the back piece.
That has got to be how they did it???
Thanks
Randall
Thanks
Randall
I spoke to one of the guys that put it on for me and he said it just took some work getting them to snap together but they didnt have to do any cutting
Thanks for the info, I just got done working on mine.
I finally got mine to fit together.
I filed a little off of each chrome clip until it fit. Not too bad.
What It looks like is GM took pieces that fit and chromed them, thus making them too thick.
Thanks
Randall
Installed mine today , took off bottom bolts and clip on each side, pushed bottom tabs and it popped out.
Getting in to snap back in was a bi*tch, defineitly 2 people, I pushed from the back off tow hook trim while my buddy pushed top of new piece in from front, :smash: took a few trys and sentence enhancers but no modification needed to do it.
  • 4 weeks later...
I havent installed these yet...there are a couple of screws that are almost impossible to get to without having to take of the front bumper.
Do you have the part number for the Z71 version of this? I don't need the black filler piece just the chrome (gray/pewter on the z71) plastic piece.
i sold mine on ebay, there was no 8 digit part number on it, but it did have a part number of anh67903 on it, dont know it it helps any
IMG 0323
Thanks. I'll see if I can find that on the GM website.
I couldn't find it with that part number. I'm just going to drop by the dealer later today and get more ordering details. Thanks
  • 1 month later...
can anybody give me step by step instructions on how to remove the plastic piece and install the chrome piece? i bought the chrome piece from my dealer today and began to install it this evening but i didnt know what screws, bolts, etc to remove. does the old piece just pop out and will the chrome piece go in its place or is there another part i will have to buy for it to snap into? thanks everyone.
  • 2 months later...
FOund this while looking for other stuff, might be helpful, but there is 4 versions of the filler panel...
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
