Weight/Tire Cert Label
Hello All,
New to this site since my purchase of a 2014 Silverado. I have found a lot of great info and inputs from all at this site. I moved up to this truck from a 2003 Trailblazer and it is used for towing a travel trailer from time to time.
My problem is I can not find the weight/tire cert label that should be on the B pillar. There is a tire label attached that shows correct size/pressure and total truck capacity. I would like to find the weight limits per axle like the label on my Trailblazer showed. Am I missing the label?
I expected a second label in the same area but there is none to be found. There is a RPO label and a bed trailer label in the glove box. The owners manual says the label I am looking for should be on the b pillar - cant find it anywhere. I guess the next step is back to the dealer.
I wonder if it's like fast food, where if they forget the receipt, you get a free hamburger? hit GM up for some free gear if yours is really missing! ha :thumbs:
I have looked over all four doors, the a b and c pillars, glovebox and even under the hood. No where to be found.
I hope its me. I think it will be a fiasco to get the dealer or GM to replace the label.
Open the drivers side door, lay on the ground and look up. it is on the very underside of the bottom sill plate area. I just found mine there today.
Please tell us you're kidding!
TJay74
You were right on the mark. I got down on my knees and there it was on the VERY lower b pillar. I feel a little stupid once I saw it!
Thanks all for your help!
Nope, not at all. Seems the OP confirmed it as well.
