My Cold Air solution.
Cliff14Denali
Ok, after hearing about guys putting on a cold air kit complaining about how loud they are I did a little research before I actually purchased my truck. I saw a video on YouTube with Air Raid's kit and something in the installation caught my eye. The Air Raid kit has another inlet coming out of the bottom by the fender. Also Air Raid did not make the MIT kit for just removing the factory baffles on the intake tube and I wasn't going to use one from a 2013 truck and plastic weld a fitting that can break. So here is what I came up with. I ordered a K&N filter to fit the factory air box and an Injen Cold Air kit(aluminum intake tube). Here is what I did step by step.
- removed to cover on factory airbox exposing the OEM filter and lower airbox.
- removed lower air box and made a template to dremel the lower section of factory air box
- removed air horn with foam that goes to fender opening
From there I noticed another opening in both lower airbox but not open on air horn........
- dremeled out air horn which had a matching opening in fender ****MORE COLD AIR*****
- next I dremeled the factory air box
- added 1/2 single sided foam tape to lower fender mount to seal lower airbox to lower fender opening*****MORE COLD AIR******
- I then removed factory intake duct work and test fit the new aluminum intake.
- measured a rough estimate length which I had to shorten again.
Once I had the aluminum intake tube to the right length, I put it all together and tighten all clamps. I started the truck and had no check engine lights......which I heard guys had problems setting off because they moved the factory MAF. My setup maintains factory MAF and airbox, but modifies it so it's not too loud.
Took the truck for a ride and you can tell I removed the factory air intake baffling, but it was no where near annoying at all. Full throttle sounds amazing.
Guys that don't want the air tube, I highly recommend doing the airbox mod by itself with a K&N filter.
So... Even though I am not an aluminum fan.... I REALLY like your setup and that was a pretty decent write up as well. I never got around to ordering the 2013 MIT kit and am thinking now that I'm glad I didn't. Do you have the section you cut off to give me a measurement of tube diameter ID or OD.
Steve, that is the one thing I didn't think of when I cut the tube......write down the measurement of the tube. The only thing that I didn't like about the Injen kit was the tube diameter is smaller than the TB outlet which they have a really nice silicon reducer to make things work. I guess the reason they would have the tube this size was it is a perfect match for the MAF which makes total sense.
I would do a measurement for you today but unfortunately I am stuck at home with a sick 1 year old.....I will try to get the measurements soon. I would do the other airbox mods and the K&N before you order the Injen intake.
Don't sweat it, I was just curious if you had a piece to measure because it looks like a simple straight tube with a 90* on one end and I can order that for $40 and just tig on a couple nipples for PCV lines. From the information found on one of the sites selling that kit, it looks like 3.750 OD/ 3.5 ID (.125 wall) tube so I will see if I can find that size online somewhere and I am pretty sure that I already have silicone hump hose and straight couplers laying around from a previous build. I just wasn't sure if a strait shot/90* would clear alternator but it doesn't look like you are having any issues so... you just opened another possible door for a custom intake. good job on the airbox also.
edit...6.2 must have a bigger TB than 5.3 because My TB and MAF seem to be the same size.
Looks nice. But I have to think having that extra big hole on the bottom of the airbox will now lead to filters getting dirtier faster. Where does that hole lead to?
That leads to the front inner fender well, not exposed to elements.....the filter will most likely get dirtier faster but that's the same thing that wil happen with an open element filter on an Air Raid, Volant, or K&N kit. Plain and simple, it gets more air into the filter instead of a hole that was only 6x8 max now has an extra 2x4 and 4x8 opening to help.
Gotcha, well that's better. I did something similar on my 2011 F150. But didnt cut anything. Just made air get to the airbox better.
Let us know if you noticed any performance or mileage increases. Although without any real data logging everything is just gonna be "seat of the pants" lol
Overall I still really like the intake tube. Cleans up the engine bay considerably.
Just being curious, but what is the part number for the intake tube? I was looking at doing that very same thing.
I was under the impression that he bought the complete CAI system for the 2014 5.3 silverado, PF7064P (polished) PF7064WB (wrinkle finish black)
Yes, purchased the kit, not just the intake tube.....
I bought the injen kit as well, installed as is for now, I was planning on doing this mod if the noise was too much for me, thanks for the info.
  • 1 month later...
It looks like I was able to double the size of the opening into the fender. Acceleration seems snappier and
it's a bit louder under acceleration. I would say the intake drone is now at the same decibel level as the factory exhaust. It's still significantly quieter than an open element CAI.
[/url]
Nice. Any mileage improvements now that you have been using it like that for a while?
It looks like I was able to double the size of the opening into the fender. Acceleration seems slightly snappier and
with the window down it's a tiny bit louder under acceleration.
Wow, that was pretty brave, lol.
    Gilkey96
    Gilkey96
  • Who's Online   3 Members, 0 Anonymous, 612 Guests (See full list)
