Thanks man.
Front 2.5" level and 2.5" block in the rear. 295's are just a tad narrower than the 305's. The difference is minimal and barely noticeable, but enough to prevent me from rubbing. I do still rub, but only at full lock in reverse. The 305's would've probably required trimming.
Thanks for the description. With the 2.5" up front and 2.5" block in the back, what is the truck stance? High in front, back or level? Thanks!
The rear has somewhere between .5-1" of rake. With the 2.5" level up front, the truck measured completely level, but looked nose high. With the larger block in the rear, the truck has slight rake, but actually looks level.
Since many people are looking helpful today. I got a question I'm looking at bigger tires and not by much maybe an inch but the weight is an additional 3 lbs. How would that much unsprung weight affect everything?
sent from Florida beech
I wouldnt worry about 3lbs. I feel like you wont notice that small a difference.
OK thank you
Going to see a minor hit in MPG depending on how much city driving versus highway driving you do. The unsprung weight is negligible in regards to steering and suspension function these would be more affected by the design and construction of the tire itself. The torque required to get the tires moving is governed by the equation 1/2mass x radius squared so the increase in diameter plays a bigger role in the affect on performance in 2 ways. It causes the engine to operate in a lower RPM for the same speed reducing the available torque from the motor and the additional diameter requires more torque to turn, it's a double whammy and you pay the price in efficiency or MPG's.
It's pretty much exclusively city driving. Boat is in city everything is here. The tires are only like 1.2 or 1.3 inches higher I just wanted something more aggressive if the downside wasn't too much. It's a cooper at. Not anything crazy massive off road wise. Just slightly more aggressive and only slightly bigger
I went from the factory 20 inch wheels with the goodyear 275 55 Sra's at 80 lbs per corner to 18 inch wheels with 285 65 toyos at 82 lbs per corner and lost about 1.5 mpg on average.
Wow from 2lb increase!
It's a combination of the weight and the additional diameter. And there's more to it than just overall weight alone. Even though they only differed by 2lbs total, the weight distribution changed. the 18 inch wheels are lighter than the 20's and the 10 ply tires are heavier than the 4 ply SRA's so more of the rotating mass moved further away from the center and since torque is mass x distance this significantly increased the torque requirement even though the overall weight did not change significantly. The easiest way to think about it is holding a hammer. It's like holding the hammer by the head versus holding it at the end of the handle, weighs the same but takes way more strength to hold it by the handle.
Makes sense, guess I didnt think through that all the way. I was thinking if I could keep weight similar Id be okay, but Im going to get dinged too then going from 20s to 17s.
Edited by jrob56
Tread pattern also has an impact as rolling resistance increases with greater tread void and construction. Comparing anything to the SRA's (which are designed as a highway tire) will likely show a decrease in mileage.
I'm not worried about mpg. I'm worried about causing damage to my truck since it's a slightly larger tire than stock
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
