fuel boost 18x9, -12 offset wrapped with toyo mt 33x12.50r18
Mind posting up a few more, or PM me? I'm on the fence about going back to chrome wheels, I would like to see a few more photos of them on a black truck, and those are one of the wheels I've been looking at.
2014 Silverado single cab. 3 inch csm level kit with 20x10 -12offset Fuel Mavericks with 285/55/r20 toyo AT2. No rub post-147889-0-25489200-1459814727_thumb.jpg
Edited by snyder5130
no problem. i'll try to get a few here or send you a few in a PM, within the next couple of days!
what color is this truck? never seen one.
It's slate grey metallic, the second pic is more accurate of the actual color.
Sent from my SM-N920V using Tapatalk
Stupid question. But why would you change gears if you got newer bigger tires? Also do you go down in gear ratio or up?
Sent from my SM-N900V using Tapatalk
My guess would be that he seems concerned about loss of low-end torque due to taller tires.
Some do it for towing others for fuel economy reasons, lower gear ratios help move the engine higher in the rpm band increasing the torque available. The change in tire height affects the actual rpm but the heavier tires also require more torque to get moving. I had a truck with 36" tires and gained 2 mpg going from 3.73 to 4.56 gears
Changing the tire size changes the actual final gear ratio. Taller tires you will want to get lower gears (higher #). If you only go an inch or 2 taller it's not a big deal, but once you start to go above 35s, especially with a higher gear you need to think about regearing. There tables on the internet that will show you what gear ratio to go to according to tire size that will give you the same performance as your stock gear with stock tires. If you have 3.42 gears and go bigger tires the truck will act like it has higher gears like 3.08s (not sure what tire size, but just an example). So you get lower gears to put the truck back to stock performance or can go even lower.
  • Like 3
Terra Grapplers on LTZ wheels with stock LS centercaps...
Can you take some more pics of your wheels and center caps? And some side shots with them too? That's an interesting setup.
Brand New this week, let the modding begin.....
Already added GMC painted wheels flares, Michelin Defender LTX M/S, Quad Fold Tonneau Cover, GMC Weather Mats, Tow-Hitch Plug, and Sunshade
Tinted Front windows and V1 Install today
Front End Leveling Kit next week
Edited by bsprtsgrp
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 446 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
