Thanks!
Toyo A/T II Xtremes - 295/60/20 on 2.5 Bilstein/RC combo level. Good clearance. No rubbing at all.
Rim width and offset?
So I just added a 2.5 Rough country level w/ blocks on some 285/75/18 Toyo ATs on my stock wheels.
I noticed some rubbing that is from one of the lower shock bolts. Anyone else encounter this problem?
Dang, that's a tall tire. What do you think of them? Any clearance issues?
You've got your strut spacer bolts in upside down. The RC instructions say to put them in from the top and now you see why, the threads don't give enough clearance for your driveshaft. I would fix that ASAP.
Yeah the shop that installed it did that. I had them fix it and then I double checked everything again. As for the tires all I had to do was trim some of the carpet wheel liner. Didn't have any other problems with rubbing.
I had this wheel and tire set up for a short while didn't like the way it looked so I sold that set. Was Nitto Trail Grabber 295/60/20 wrapped around a set of KMC XD 20x10 Monster 2...
I'm now running stock all terrain 20s wrapped around a set of 285/65/20 BFG KO2 and I absolutely wouldn't change a thing. The left is a a 4.5 inch suspension lift made by zone
Looks sharp!
What's not to like that is the first time I seen that wheel. Did you have rubbing issues?
Cbass953
No rubbing at all, the only reason I took that set off is with the Zone lift my front wheels with that set up stuck out a county mile. It looked funny!!
They were 20x10-24!
I now have stock oem All Terrain 20s and to flush up the back with the front I installed 2" wheel spacers in the rear.
Now it looks alwesome more stock then I wanted but looks sharp! I'll post updated photos soon.
Do you have a pic of bfg's. I was thinkin about running that size one of these days. Truck looks great btw.
Just got some 305/55/20 Nitto Exo Grapplers.
4a6eecdcb1d12e305bc119ce9fe0ddc3.jpgcd421a983af2a275701ef7ae9be24b20.jpgae79e5634a6500f0cc70e7d731562874.jpg
Running Ko2s before right why the change?
Running the KO2s as my winter setup, and wanted to go a bit wider. So far so good with the Exos, bit of rub though
Gear challenger 20x9 0 offset pvd chrome, 275/60r20 Toyo open country at2
2.5" RC level kit with rear block
Edited by hake
I had that same problem but with a 2 inch zone kit. To solve the problem I added a washer to the bottom bolt
    KJEK
    KJEK
  • Who's Online   3 Members, 0 Anonymous, 642 Guests (See full list)
