Any rubbing?
It rubs a tiny bit at full lock if the ground is not flat and a tiny bit during very hard cornering when the body rolls.
I'll check it in a few weeks and do some trimming if needed.
Truck looks great, really dig those wheels!!
Thanx, they suit a lowered truck, lifted or level, maybe not so much.
Edited by Allgonoshow
Hey guys quick question I'm getting ready to put some 20x8.5's with 305/55/20's on my 2015 Silverado 1500 with the RC 2.5" leveling kit. I know it won't rub if I mount them like that but if I add 1.25" spacers will it rub? Any input appreciated!!
That will depend on your offset and back spacing but I have 20x10 -19 with the same tire size and I rubbed at full lock until I did a bit of trimming. Hope that helps.
I have read every page on this thread and teh level thread looking for wheels. Looking for something that looks good with a 16 crew cab. Deep ocean blue metallic. I like the fuel maverick and throttle but not sure on how thy would look with the blue. Will be a 20" wheel. Any ideas on what looks good with that color? Thanks
IMO for color Gun Metal looks amazing on the blue. As for design, that all depends whether you like a "busier" style or a simple one.
They have +20 offset on them
Edited by Albertogf
I have 305/55/20 now on 20x9 0 offset and had to trim. Rub is worse on driver side vs passenger for some reason.
I could be wrong but 305/55 might not fit on a 8.5" rim.
It does fit them, and it doesn't seem to rub as it is but I'm waiting on my lug nuts to get here so i can try them on. I got them at a great price so i didn't argue the width of them too much, but i wanted to try spacers for a little while
Haven't seen many in gun metal. As for tires I had the Terra grappler on my 14. They weren't very good in the snow and mud. I would like to get a taller tire that doesn't stick out. Still learning this offset and tire size. Any recommendations on size. Will be a 2.5 RC level kit.
2016 Silverado Crew Cab Texas Edition
2" Level
20X9 Fuel Throttles
33X12.5X20 Federal Couragia
Do have any side pics? Looks great!
3" leveling kit and 2" wheel spacers with stock wheels and tires for now . going with 275/65r20's on the stock wheels real soon.
13232877_941047639347947_826692151642981
13010671_924853150967396_908134986836262
13265843_942925059160205_753632788425496
Edited by siguy76
Siguy,
Few questions. What kit did u do? I have a 3 inch level from motofab on stock 18 inch rims and tires. How is the feel in power loss going from a 31 inch tire to a 34? Do you mind measuring the height from the ground to the fender. Curious on the total height. Also what spacers did you use and where those factory rims factory black or plastidipped? Thanks
Sent from my Nexus 6P using Tapatalk
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
