Haven't seen many in gun metal. As for tires I had the Terra grappler on my 14. They weren't very good in the snow and mud. I would like to get a taller tire that doesn't stick out. Still learning this offset and tire size. Any recommendations on size. Will be a 2.5 RC level kit.
A lot of guys running 275/65-20's (34") with the 2.5 levels. Can't confirm clearance myself though. As for offset, my 20's are 20x9" +15 offset, and with the 275/60-20 (33") they are as close to flush as you're going to get. The rear sidewall is about 1/4" or less inside, the front is 1/4" or less outside.
Thank you! Can't even tell you how many pics and pages I have looked at in the last month. I think I'm gonna go 20" fuel mavericks and Toyo at II tires. Not a 100% sure yet.
Sent from my XT1254 using Tapatalk
Closest thing to a side profile I have right now, gives a good idea. Toyo AT2
9F0754A0-9D7A-4367-B447-C4D7701B523F_zps
Looks sweet! How are they off road? We get a lot of snow up here. Thanks
Haven't found out yet. But I'm in Edmonton Alberta, so I'll find out eventually.
Here's my truck with fuel maverick and toyo at2
Great looking truck! Wonder how that would look with deep ocean blue metallic
Jeff5347
its a 3" motofab kit. the wheels are factory painted 20's because i have an "elevation edition" truck, the spacers i am using are BORA hubcentric 2". as for fender height i will tell you by the end of the week when i get my 34's on it !
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
