Floating tach needle
I noticed on my way home from the dealer on the interstate that when in 6th gear the needle floats up and down down couple hundred rpms. Anyone else having this happen to them? It happens in other gears occasionally too.
The converter on the 6 speed transmission is constantly slipping and engaging/releasing depending on load and speed. I have seen this truck and my previous truck do this as well. Only way to fix it is via a tune and setup the TCC to lock/unlock quicker. The factory does it so you don't feel the TCC engaging/releasing like on the older 4 speed transmissions.
Here read this, this might be related to your issue.
brandon1282, on 14 Nov 2013 - 4:28 PM, said:
Just to update everyone on the rumble strip vibrations I was experiencing. I got the truck back 2 days ago and so far so good. Here is what the dealer reported:
Road tested vehicle and found possible tire/wheel vibration. Removed all four wheels and road force balanced to find one tire out of range. This tire was replaced and then vehicle was road tested again. The vibration improved but was not eliminated. Checked for TSB's and none were found that directly addressed this concern. Contacted TAC and TAC suggested to utilize TBS PIP5149B. I followed all instructions of this TSB, checking for excessive spark retardation and connecting rod oil squitter condition. There were no conditions observed. TAC then directed me to utilize DOC ID#2102430 where I checked the operation of the control solenoid within the transmission. When commended to the on position, It registered full pressure and when commanded off it registered 0 pressure. After completing all tests found that TCM could not be 'pulse-width' tested, only command on or off. With these measurements we determined that the TCM was sending an erratic signal causing the torque converter to be commanded erratically. This caused potential damage to torque converter. Therefore, I replaced the TCM (Signal) and torque converter (damaged internally). Road tested vehicle; now operating to GM specifications with no vibration when tested under the original conditions.
I have also noticed that the "floating Tac" condition I had earlier is no longer present.
Don't listen to Won, he is the the biggest troll of this forum. He actively tries to induce panic in new forum users inquiring about an issue.
This is the correct answer.
So taking it to the dealer is basically going to be a waste of time?
Yes. There is nothing wrong with your truck.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
