GMC 1500 SLE 4x4 ext. cab sb 5.3l 2014 brand new today
HI all,
I just drove my new truck home today from a dealership 30 miles north of me here in SW PA.
I was looking around for a forum to join and landed here from a Google search. While googling, I also found something disturbing
on another site: http://news.pickuptrucks.com/2014/01/recall-alert-2014-chevrolet-silverado-1500-and-gmc-sierra-1500.html
Then I read the recall due to a fire hazard from a leaking oil line here on this site. Do I need to worry?
When I parked my truck in the garage I could smell the "new truck" smell of something hot. I thought it was just due to it being new and maybe the exhaust and/or cat. was burning in. Now I'm paranoid. I sent an email to the dealership just now. Guess I'll read it tomorrow.
Jim
I had the exact same smell on my new Silverado High Country. I was freaked out about it and the recall news. The smell went away after about 200 miles and a couple weeks. I would not worry. I checked to see if my truck was on the recall list and it was not. Enjoy your truck. Yes there have been some QC issues, but I personally love my vehicle. Stop reading about all the people who have issues and the recalls and just enjoy the new car.
Congratulations! Upload some pictures.
Thanks to all who responded. The dealer informed me that my truck was not on the recall list.
anonymouse, I'll get some pics to upload soon.
99silveradoz71....nice truck!
darylz71....I'm near Somerset, Pennsyltucky :dunno:
Thanks again,
Jim
JimthePAHunter,
Congratulations on the purchase of your new vehicle! I understand that you may have some questions or concerns regarding your new vehicle and open recalls. Please contact us via private message if you have any lingering questions or concerns.
Jennifer T.
GM Customer Care
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
