Tobtek, have the rear end gears been replaced yet? For what I'm seeing on the tahoeyukon.com forum, replacing the rear end gears is the only thing that has worked (twice, so far) to eliminate the buffeting/drone/pressure problem.
My take is that there is something NG with the original gear sets that is the root cause of the buffeting/drone/pressure. But, the overly stiff shocks makes it even worse. Fix the shocks and the harshness goes away, as does some of the buffeting/drone/pressure, but also need to have the gears replaced. And, by the way, need to have both rear and front done. One of the folks on the pickup truck forum dealing with the "vibration" issue noted the dealer changed the rear end gears and the vibration went away....until he put it in 4wd! I notice more vibration in the steering wheel in 4wd. And, the vibration is the root cause of the buffeting/drone/pressure, I think.
Replace shocks and both gear sets, and we might just be out of this mess!!
I'm not sure if this is good news or bad for those of us with this issue. I did a query on SAEs website to see what kind of technical papers may have been written on this kind of issue, if any. I searched for "booming" as the SBs I've found use that term to describe the pressure/noise we are experiencing. Guess what I found?
http://www.sae.org/search/?qt=Booming&sort=relevance&sort-dir=desc&display=list&taxonomy=&sector=%28%22AUTOC%22%29&content-type=%28%22PAPER%22%29
Hundreds of papers written by those in the automotive industry regarding booming noises in automobiles. I even found a couple of papers on line that mention the pressure sensation associated with these low frequency sounds. So, this issue is nothing new to the industry, and there is lots of science out there. That's the good news. The bad news, is this is a complicated phenomenon, not easily corrected. Complicated even more by the fact that some vehicles don't exhibit it, and some don't initially and then suddenly develop it. Even Jansondenali mentioned that with his second Escalade.
Of course, this is way beyond what the dealer can do. This is GM heavy engineering stuff.
And, to really make it interesting, check out this write up on the GM Terrain when they brought it out.
http://www.engadget.com/2011/02/25/gm-shows-off-terrain-suv-with-noise-cancellation-says-silence-e/
So, GM knows all about "booming" noises in the vehicle, especially when running the engine at low rpm's for improved fuel economy. The solution - try to use noise cancelling technology to hid it. Of course, if the noise cancelling system doesn't work well enough, then the noise will still be heard. Of course, that doesn't explain the vehicles that don't have noise cancelling, like the Yukon SLE and SLT's.
The plot thickens!
Total MESS...Yes. But No, they have not touched any of the gears yet. Been dealing with the nice people at the GM Corp office again. Trying to get the authorization to switch out the gears, AND try some softer sidewall tires. I've been in vehicles with over inflated tires, and had similar sounds as our Escalade is producing. ??? While at the service dept this time, Maybe they can fix all the other issues.......I know, wishful thinking.
Just got wife's 2015.5 Yukon Denali last week and I can't stand the pressure on my ears.. I first was checking the bass on the radio them realized after a while it is the truck. It really annoys me and I don't tell her in case she hasn't noticed it.
If you are in the market for one of the 2015 GM Fullsize SUV's (GMFSUV), conduct this test first. Drive a GMFSUV(1) non-extended version, base model, 20 inch wheels or less, with Premium Ride Suspension. Then compare the ride to a GMFSUV(2) extended version, bells and whistles, 22 inch wheels or more, with Magnetic Ride Suspension. This comparison is not definitive because most GMFSUVs 1 and 2 are trouble free, but based on input on this thread from "owners", the GMFSUV(2) will more than likely exhibit issues of buffeting and pressure on more occurences than the GMFSUV(1)
GM has not figured-out or yet published information to answer problems associated with buffeting and pressure with the 2015 year truck, if you purchase a truck with these problems you will definitely regret it. But if you just got to have one of these trucks, the test may allow you to get lucky and your truck may not experience any issues at all.
Reference back to the cotton ball trick I did w/ the mics.. It takes literally 10 mins to do.. Since you aren't experiencing buffeting, the pressure can be fixed by deafening the mics.
Edit: I'm going on 8 weeks now w/ no pressure.. I did have to replace the cotton balls w/ fresh ones, but so far, it's worked perfect for me.
Edited by 20Sierra14
I was running the other day and a Tahoe was coming towards me up a small hill. As it got closer I could hear a kind of humming/droning sound like it was lugging before changing gears. Has anyone else heard something like this outside the vehicle?
Hi all, I'm new to the forum.
My wife and I have been loyal GM customers for quite sometime now. In particular, my wife has gone from Equinox to Envoy to Yukon to Suburban to her first NEW 2015 Suburban LTZ, which she slapped down 70k for.
What a disaster. She's had the car for less than a week and cannot stand the vibration inside the cabin. Her ears (and mine) experience the pain/pressure like so many others on this forum. I can't have my kids in this car!
In addition, apparently the new engine is much louder than the older models. She traded in an '08. The 2015, apparently because the way the new engine is made, maybe because of electrical components, makes a ticking like noise at idle. Disappointing, but bearable.
We just called the dealership today, and left a message for the manager that we will likely be having them buy the vehicle back.
With this looking like an issue with Cadillac, GMC, and Chevy, what the heck are my options for a large SUV? We have 4 kids, and my wife WILL NOT drive a minivan. Are my only options to go used? If so, how far back do I need to go to find something without this vibration issue?
Thanks all!
Dadof4 - Unfortunate that this is your first post, hope everything works out at the dealership. I own a 2015 and 2001 model and just got rid of my 2008 model. My '01 and '08 generations did not have any issues associated with this thread, neither does my '15. I don't have knowledge to comment on other manufacturers Fullsize SUVs, but for GM, you may not have to go back any further than the 2014 model if GM ends up being your option.
Or you could try a loaded Traverse LTZ if your dealer will work with you. My wife has the Acadia, and it seats 7. Drives like a car, but it won't tow like a real SUV (thats what the Avy's for).
Thanks all!
Don't wait. Get your money back ASAP. Get a claim number from GMC customer service to get the ball rolling. There is NO fix for the ear pressure sanctioned by GM. All they will do is rip apart your truck and hand it back to you in worse condition than you received it...with the ear pressure problem still persisting. Trust me, I have been down this road...twice. Just get your money back.
@dadof4 - With this looking like an issue with Cadillac, GMC, and Chevy, what the heck are my options for a large SUV? We have 4 kids, and my wife WILL NOT drive a minivan. Are my only options to go used? If so, how far back do I need to go to find something without this vibration issue?
We are in a similar issue as you trying to find the large SUV for myself and family, since the big mess with GM. After looking for for the last nine months in complete frustration we are considering either 2014 Yukon/suburban (no issues) or 2014/15 FORD Expedition EL (augh) for the room. There is nothing else out there smaller that has the comparable room besides the dreaded mini van. Believe me we have driven them all trying to make something work. Sincerely Wish you much luck with your search!
2014 (Chevy) rear shocks are inferior to the current and prior versions, but this is an excellent version. Replace the OEM shocks with quality aftermarket and this truck will get the job done.
Edited by The Zip
Could this be related to the aero dynamics of the roof? Our last (09 Denali XL) had no noise at all but from time to time I would tow a buddy's enclosed trailer and that would cause an extreme buffeting noise around 40 mph. I could tow other trailers with no noise what so ever. Just has me thinking that if all of the new trucks do this perhaps there is something aerodynamically with the roof line that is causing this?
Perhaps to some degree..... maybe?? Our 2015 i Escalade is most annoying around 20-30 mph going over uneven road surfaces. That would lead me to believe it's more of a tire/shock/suspension issue. The bumps radiate a booming sound through out the cabin. It sounds exactly like the stereo's subwoofer is working on its own. Our Escalade is going back in tomorrow AGAIN for more trial and experimentation. Hoping to try the new front and rear ends, and softer sidewall tires. I Really think the rear end isn't right on ours. Coming to a stop you can hear a high pitch whining sound back there, and if you let off the gas while going down hill the rear end back lashes and slaps the whole truck forward. LoL.. Was dropping the kids off at school last week and it did this so bad, my girls were saying " Dad, why did you have to do that" it's really bad. Has to be something to this! It's sounds like the gears are to tight maybe, not enough clearance or free play??
And of course it's in for the Non Op Nav system, the rear suspension that's still squeaking, the transmission issue that feels like it's in 20th gear when driving slowly, then It usually has a " Chirp" sound back in the exhaust system when giving it a little gas as well. The non op blue ray playback issues. Etc, Etc, Etc......
Love this new truck. It's so neat :( ..... What a complete piece of junk!
This whole fiasco should be completely embarrassing for General Motors. I just yesterday completed my JD Powers and Associates survey, would be really interesting if anybody contact me about the comments I left.
Edited by TOBTEK
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
