My bows came over of the course of weeks. I suppose you could try that and see how it works. That really is the only way to know, by trying it.
Maybe the best approach is to get the bows fixed and then install it right away to keep them attached?
Frank
Frank
Right, only right after the GM "fix" is applied. Maybe I'll give it a shot.
Guys,
I seriously think the problem lies in the hatch door. The buffeting in my car was coming on and off on the same roads on different days. That was because sometimes the door is properly closed and other times it is not. Last night I observed it clearly. I drove with my friends to the city and it was buffeting like hell. My friends noticed as quite bothersome. Then, I opened the hatch door and slammed it hard. After that buffeting disappeared (or at least 80% of it), and it all felt like normal, even driving on the same roads.
I believe if the rear hatch door is adjusted properly, seals are fixed, and vibrations from wheel are fixed then buffeting should disappear, or at least most of it should disappear.
What do you think is causing the booming noise when driving over bumps in the road? Im not suffering from buffeting at highway speeds, just the ear pressure and the booming.
Edited by Ozzii
That *could* be related to the hatch as well, IMHO. The hatch might be bouncing down into the opening of the truck as it bounces up over the bump. I thought I had improved it with my foam experiments, but I couldn't reproduce it. The booming is prominent when driving over snowy roads.
Adjusting the stops on the hatch can also make the buffeting better/worse. I wrapped them in painters tape and make 1/2 turn adjustments at a time.
My Yukon will be going back to the dealership soon for a close examination of the hatch and the seals. Among other things. I'm sure they've got better ways of ensuring proper fitment.
My experiments are on hold because it's gotten cold and I have had little time. Though I did try removing the amp fuse (#48 on passenger side) last night to rule out ANC. It made no difference to the buffeting.
Guys,
I believe if the rear hatch door is adjusted properly, seals are fixed, and vibrations from wheel are fixed then buffeting should disappear, or at least most of it should disappear. AMEN sas06, I hope they listen to you. I have known this all along and no one listened . They would rather rip the interior out, yank the exhaust off, putty/caulk the roof, buy off brand tires and wheels, mess with the radio, yank fuses out, pull out the drive shaft, rip out the rear end , disconnect the air line from the new shocks, replace the shocks with aftermarket junk, pull the fenders off and add supports, re flash the transmission, and even tamper with the motor on a $70,000.00 brand new car. Geeze Louise !!! Unbelievable........... All the best, Booty
Edited by Booty
To be fair, GM did mostly eliminate my vibration issues by replacing 2 tires, road force balancing them all (twice) and replacing the rear axle.
It's the buffeting that hasn't been fixed. And the hatch is now a target for examination...
Edited by FogDucker
Thinking outloud
If the rear hatch was the true source of the issue, don't you think GM would have fixed that by now almost 1.5 years after the initial reports
It would not be expensive for new bushings, tighter couplings, new lock, etc
The roof, OTOH, is a major repair expense and even more so if you want to redesign it mid production
Edited by boazEarl8
I should also say that:
For me as the buffeting has been varying from time to time, it also has been varying from speed to speed, disappearing and reappearing at various speeds. This too can be caused by varying situations of the rear hatch.
I have played with door stoppers as well as felt pads. Each change of circumstances changes the level of buffeting and the speed at which it occurs. Last few days I roamed in the city trying to find roads where buffeting does not happen. I found one recently built. This road is super smooth with almost no imperfections. There is almost no buffeting on this road even at very high speeds. I think as the rear of the car (being extra long) shakes/vibrates due to imperfections on the road the hatch may not be able to hold to its strength causing the buffeting to occur. Felt pads are no solution as they tend to leave room in between doors. One should get the seals fixed and the door adjusted.
As FogDucker has said, the booming and buffeting both seem to be caused by the hatch. But I would still not completely discount some role played by the roof sheet of metal. As Frank has reported a fix earlier. I would say it could be either one of these issues or it could be a combination of both. But hatch should be a starting point of investigations.
Edited by sas06
Have to say if media reports, including this forum, are correct about the quantity of suv examples that consistently exhibit these problems, then GM must already know the cause of the problem. They've had ample time and certainly have the engineering resources to figure it out. This isn't some anomalous electrical gremlin affecting a handful of vehicles.
Think the real issue is whether they feel compelled to put what is likely a costly fix into production or want to band aid the affected owners/units until a mid cycle redesign.
I think that GM has been barking up the wrong tree, confusing buffeting with vibrations. They're looking at it as if it's the same problem and I don't think it is.
When I first reported the buffeting to my dealership 3 months ago, they declared that I had vibrations. I didn't disagree. A few visits, parts and picoscopes later, my vibrations are 99% gone. My Yukon is smooth right up to 90mph. The vibrating, it turns out, has nothing to do with the buffeting. They may have incorrectly assumed that the vibrating was causing the buffeting.
The biggest challenge with the buffeting is that not everyone can hear it and even if they can, everyone will interpret the severity differently. Everything from "Holy sh!t, my ears are bleeding and my head is going to explode!" to "Whatever, it sounds like we're in a tunnel." Very subjective. Then add the fact that it's prominently heard only in the driver's seat, only at 2 speeds [40mph and 70mph]. Then add the fact that there doesn't seem to be any consistent or cost effective way to measure buffeting either, at least that I've found.
The fact that my dealership and GM field engineer(s) are still actively working on trying to resolve the buffeting tells me that they don't know what the root cause is. If it really was an expensive fix, they would have told me to pound salt or agreed to take my truck back. It's possible that they've had the wrong people working on the issue - drivetrain specialists instead of noise & vibration specialists. It's also possible that GM doesn't have the right tools or expertise to properly diagnose this issue. All we can do is speculate because we have little or no visibility into how GM is managing the buffeting issue. Well, speculate and MacGyver with our $70K trucks, pulling fuses, removing panels, removing spare tires, manipulating seals, adding Dynamat to our roofs... If anything, we are a persistent bunch that really like our trucks and want them corrected! I sure as hell do!
That's why I think it would be totally awesome to have an expert in vehicle aerocoustics get involved. PhD grade that has spent years living and breathing this kind of stuff. Someone like Franck Pérot from EXA.
My thoughts are: The hatch is positioned to the body by robot. Then the human worker installs the bolts, then somewhere down the line the gasket is installed, the hatch is closed and the car moves on down the line. The hatch is large in area (big drum) and is exposed to lots of air pressure. So with a lousy weak seal/gasket and a misaligned hatch and latch you will get the drum affect in your ears. I do not know why my hatch is tight and others are not tight ? Are there 2 robots that place the hatches to the bodies ? And one is calibrated different in the positioning spec ? Is there a real inspection on the closing of the hatch or " Yep, she closes she does, she does" "Move her on down the line boys " Hee Haw type of inspection ? Maybe our GM "line experts" will respond with an answer. With best regards, Booty
My experiences of today:
I went to back of my car opened the hatch and started looking at various places in detail. I noticed that the hinge on the right side did not seem symmetric to the ones on the left in terms of how they were joined. The positions of the bolts were slightly different. Upon a more careful inspection I found that the hatch was leaning down from the right side slightly (not easy to notice though). I could also point out the impact point of the hatch to the body on the right side (at the bottom of the hatch), some paint has also been damaged there.
Then I opened the door stopper of the right side as much as I could and also opened the left one but only slightly.
Upon driving I noticed considerable change in conditions as follows:
1. Booming was now less bothersome to the ears. It certainly lessened. I am not completely sure whether it was because the cabin was now less air tight or because the hatch now didn't made the impact on the body.
2. Also noticed that the road noise was slightly more than before. This can be certainly due to the fact that the cabin is now not as air tight and noise can easily come in.
3. Buffeting also kind of lessened and changed as well. What I noticed was that while driving when the speed of the car stabilizes to say 110 Kmph and stays there. At this point as soon as there are sudden imperfect road conditions the buffeting happens for a while and then subsides and so on. I guess the hatch could now be a bit more shaky on rough surfaces due to road impact.
But if people believe that had the hatch been the only problem, GM would have fixed it long ago and the problem is actually deeper... THEN ... my theory is that the cabin in these cars may not be balanced/symmetric in such a way that the hatch finds it hard to settle down and buffets. I hope my theory is wrong because if it is the problem with the cabin itself then it may not be fixable.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
