Chris Posted August 11, 2014 Posted August 11, 2014 I am starting a new side venture and I need to drill post holes into dirt for real estate signs. So I need to know where I can get an auger or the attachment to make it work with a drill.
00Silverado4x4 Posted August 11, 2014 Posted August 11, 2014 Do you have Tractor Supply stores or Harbor Freight out your way. They should have everything you need.
Chris Posted August 11, 2014 Author Posted August 11, 2014 I've got both, but dont know exactly what im looking for. Since this is only some side work I dont want to go all out and buy a gas powered auger.
00Silverado4x4 Posted August 11, 2014 Posted August 11, 2014 What kind of drill do you have? For post holes your going to need quite a bit of torque to dig down.
Chris Posted August 11, 2014 Author Posted August 11, 2014 Im buying a New one. It will be a dewalt 20v
00Silverado4x4 Posted August 11, 2014 Posted August 11, 2014 Not sure if that will provide enough "umph" to drill post holes. Of course once you find the attachment you could always fab up a lawnmower engine. It would beat buying a new engine.
Chris Posted August 11, 2014 Author Posted August 11, 2014 Basically drilling a 2 inch hole into a front lawn. Shouldnt be that hard.
00Silverado4x4 Posted August 11, 2014 Posted August 11, 2014 Ahhh, 2" holes, that sounds better. If I recall Lowe's has the really long bits for that purpose. If I am remembering correctly.
Chris Posted August 11, 2014 Author Posted August 11, 2014 My family has a real estate brokerage. I dont want to get my license but I can make $25/hole
RyanbabZ71 Posted August 11, 2014 Posted August 11, 2014 Menards here sells them about $400 for the entire post hole digger My family has a real estate brokerage. I dont want to get my license but I can make $25/hole Start digging all over haha
Chris Posted August 11, 2014 Author Posted August 11, 2014 Menards here sells them about $400 for the entire post hole digger Start digging all over haha Basically trying to keep the business all in the family. $25 for 30 minutes of work isnt bad.
TimmyG Posted August 11, 2014 Posted August 11, 2014 Must be pretty soft ground. I was smoking a 8in bit in a gas powered one while trying to add a deck
RyanbabZ71 Posted August 11, 2014 Posted August 11, 2014 Must be pretty soft ground. I was smoking a 8in bit in a gas powered one while trying to add a deck We are all clay here Outsource cheap labor haha
GasHog369 Posted August 11, 2014 Posted August 11, 2014 As allready stated you are going need a lot of torque. A 20v drill wont necesarily provide the power tyo go through clay / stone / slate / etc... I have seen these before tho and you can try it.. http://www.amazon.com/Yard-Butler-IRP-3-2-75-Inch-Diameter/dp/B00EOMCM4W/ref=pd_sim_sbs_lg_2/191-4966642-3765707?ie=UTF8&refRID=0HS32S9804EY0SD5W0R8 If anything, i would more recommend a right angle hole hog style drill made by milwaukee that is built for boring holes in studs and mixing mortar etc.. But you would need power to run it.
Mckenzie Posted August 11, 2014 Posted August 11, 2014 We got a badass auger for our skid steer but thats supper expensive! What about some old fashioned post hole diggers?
