Temperature Display Stuck on 86 Degrees
Does anybody know if there's a way to reboot the MyLink system and maybe reset the temp display to allow it to display the outside temperature correctly? I hate to have to take it to the dealer for this minor problem but I will if there's no other option.
Tapatalk via iPhone 5s
Have you tuned it recently?
Leave the driver door open for 5 minutes with key out of ignition. Sounds funny but I called GM when my link was acting weird in my truck. I laughed but that's what they told me and it worked
Maybe unhook the negative battery cable? Beautiful truck, by the way.
Thanks for the compliment!!!
I thought about the battery cable thing but didn't know if it would erase all my settings. However, I ran an errand last night and it registered 91°. It's been over 100° here for the last few days but, according to my truck, it stayed 86° 24 hours a day for over a week :(. I guess it cleared itself for whatever reason but I'm not complaining!!
I'll keep this in mind in case it loses its mind again later down the road. Thanks for the tip!!
No, not yet.
I was asking because mine did the same thing after tuning, it cleared up after a day or so. No problem since.
Well mine now reads 32 degrees and it's 102 here today. Called the dealer and am taking it over at 8:30 in the morning. They said it was probably the sensors located behind the grille.
Tried it this afternoon and nothing changed.
Tried it and it went from 86 degrees to 32. That's where has stayed since.
I noticed mine was stuck at 82 degrees on Saturday, but it was 101 here. I forgot to look today if it corrected. Strange issue.
I disconnected my battery in the morning and plugged it back in at lunch to reset the computer (dealer put 87 octane in it when I purchased it). After plugging back in my outside temperature was stuck at 32 degrees. When I went to leave work that day it was working again. You may just need to give it some time to reset after disconnecting the battery.
