Leaf Spring Squeaks/Creeks-2014 1500
pj8556
  • 2 months later...
  • Replies 42
MY 16 has started to squeak bad when under 30 degrees in the morning while going over speedtables. Sounds worse than my 01 Tahoe with 200k + on it.
Hi 20feetup,
We can imagine how displeasing this squeaking concern must be. If we can help in any way, feel free to send us a private message with your VIN, contact information, and servicing dealership.
Regards,
Anthony
GM Customer Care
The grease was applied to the pads at the end of each leaf. You can see the grease so I know they did it. However, after initially being "fixed", the noise is back. Not happy. Now i get to find even more time to waste taking my truck back to the dealership to repair.....again.
Wash the ends of the springs with a pressure washer. Afterwards, spray the plastic pads with a dry lube, either graphite or PTFE-based. Grease attracts dirt, which works in between the plastic pads and the main leaf spring, creating the squeak. If it still squeaks, the pads could be damaged or the leaf spring bushings could be the source of the noise.
  • 3 months later...
  • 1 month later...
My 2014 Sierra Denali with 49k mi is driving me nuts with the leaf spring squeaking & creaking! I have sprayed some fluid film and it fixed if for a month but it's back. Worse in humid environments. Is there a good solution yet? Updated leaf spring pads? My 2010 never had this spring noise! Come on GM, a $60k truck should not sound like a 1955 pickup in parking lots...embarrassing to say the least.
  • 5 months later...
I’m from saudi arabia and i have a 14 sierra 1500 z71 , SAME PROBLEM , it only has 70.000km on it , I’ve had an 11 gmc sierra truck , it had a 300.000km on it , NOTHING WAS WRONG WITH IT , the dealer refused to help me , literally the exact same thing happened to me
  • 3 months later...
Mine recently began making a pretty loud clunking sound so I took it to the dealer and they said the leaf springs need a shim and lubrication but I also had a loud squealing coming from the front whenever I turn and that turned out to be the calipers so they replace the calipers and brake lines under warranty because they were sticking but then wanted $1,069 to replace the front rotors front pads turn rear rotors and replace the pads so I said just do the warranty work and took it to mr. Tire for brakes they said the back was fine didn't need any work they said the front rotors had plenty of meat so turn those put new shoes on front $259 and they didn't fix the clunk because apparently it wasn't covered under my extended warranty I despise going to the dealer for maintenance. You'd think of the pads wore out prematurely because of faulty calipers they would be covered.
  • 3 months later...
My truck is making this squeaking noise. I noticed the middle spring is shifted on both sides and scraping the shackles. Dealer sprayed grease all over them and said it's ok. 3 Spring shops have all said it needs to be replaced. Truck back at dealer now with this issue, loose steering, and ball joints popping w/ steering sway.
Will also be requesting GM employee signature stating everything is fine, then taking to a front end specialist and suspension shop for expert advice.
Purpose bought truck for towing and now too afraid to tow with family inside.
Forgot to mention. Based on the price of the leaf spring assembly in comparison to the labor rates of continuously cleaning inspecting a greasing these things, it would be far more cost effective for GM to replace them up front. I guess the new GM maintenance concept and philosophy is the reason behind the continuing rise in unit costs.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
