Need a new battery
So the battery in my 07 NNBS truck is finally giving up. Its the original battery that came with the truck. What brands are the best mostly lookin at store brands as i'm tryin not to spend 200+ on an optima. NAPA, Oreilly's, duralast, or even interstate is what I basically have access too. Theres energizer at SamsClub but they seem to have crappy reviews. The walmart brand one seems to have good specs and a good warranty, but you know buying auto parts from wal mart seems a little sketch. I have sears in the area too but their website was being dumb so couldnt really see what they had.
If your OEM lasted this long, why not OEM? I have always had good luck with delco. And looks correct in the truck.
My service mgr at the dealer I use said buy it here and we install at no charge. Do not have to haul old battery back etc...
I have always used duralast until recently when I purchased a Kirkland battery from Costco. The Kirklands that I have used have always performed well in all of my vehicles from my HD sierra to my old honda accord. I have also found them to be very cheap as well costing around 20 bucks less than the duralast counterparts. So for me it's Kirkland and if they don't have the one I need then it's straight to duralast.
thought about it but didnt see it at the part stores, never really thought about going to a dealer though. Ill see who has them.
Check around, Certain part stores here carry them, if you rather diy. All GM dealers carry them. May have to ask around for free install if they do not know you.
Not cheap but my 09 oem is still going?? knock on wood. Most batteries today do not have prorated gty, They just carry a full replacement gty for so many months. At least with Delco, this is how it works. Delco has several levels based on cost. I think the top of the three at my dealer was around 160+/-??
Diehard Platinum is a great, but pricey, battery. Similar in construction to an Optima.
Since a Platinum wasn't avalable for my 2500, I went with the DieHard Gold Advanced. It's also an AGM battery, and about $50 less. If you buy/pay online, you'll pay less than paying in the store.
Both have a great warranty, and I've had zero issues with them. Now that I did the aux battery mod, I have two of them under the hood. Will never worry about a battery ever again.
Well i went with an ever start maxx h-6 from walmart. 730 CCA 900 at 32 degrees. was 117 plus tax. Has a 5yr warranty with free replacement for the first 3 yrs and proration for the last two. Had the best CCA I could find for the price and the warranty seems better than most others out there. Looks really similar to the original that came out of the truck.
Almost want to do the aux mod in my 1500 just because the main one is such a pain to get out.
I had a duralast gold up until this summer and it lasted 4 years. It wasn't dead yet but it wasn't holding charge very well and I just swapped it out preventatively.
Make sure to buy the grease and fabric ring things to save the posts and cables from rust.
I recently replaced my oem battery in my 08 with a DieHard Advanced Gold AGM Battery. Was able to find it at sears on sale for less than $150.
I got my optima on ebay new and fresh for $157 shipped
didnt think to look there, sometimes i forget about ebay to just buy things on
+1 on the Costo Kirklands. I have them in all my cars. They are made by Johnson Controls (who makes most batteries), it is thier top of the line model with a 3 year free replacement. I had an Optima in my K1500, it lasted 4 years. Not bad, but the Kirkland lasted 7 years, and they gave me $30 when I returned it! Now I don't drive the truck a lot, but 7 years is good just to sit on shelf. Oh, and it was half the price of the Optima.
I used to buy Delcos, but the 2001 factory battery failed after 2 years, leaked acid out the post, corroded my starter cable and bracket. My brothers 01 Blazer did the same thing. Delco lost me as a customer for that. (The dealer did replace my starter cable under warranty)
Delco stuff is not the same since GM sold it off.
What he said ^
I would buy a Kirkland (Costco brand) battery, OR an Interstate Battery, which is also made (in USA) by Johnson Controls.
yeah the wholesaler was out of Wisconsin... I don't have a Costco or anything here so I can't vouch for the Kirkland but it sounds like a good deal too.... Delco replacements... Well I got a year out of the last one.... Never again.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
