I have a 1999 chevy silverado 1500 with a long bed that needs replaced. Will a long bed from a 2004 silverado 1500 bolt right in and will the tail lights work with the wiring harness?
^ haha soo very true. I'll be interested to see if it can swap over. I wouldn't bet all my money on it, that's quite a year gap. It'll be good to know though for the future.
Bed it identical. Your old harnesss and lights will go right in.
1999 was a split year. OBS vs. NBS.
Otherwise, if your on the correct "NBS" path, it will interchange. GMC's had a slightly different t/lamp socket than the Chevy's too. With a minor mod (via a razor blade) the t/lamps will ALL interchange!! :cool:
Edited by Bad Bowtie2
03+ tail lights plug right into 99-02 beds...
I also bet that its a direct swap.
Need the 03+ tail light harness or mod the 99-02 plugs
  • 4 years later...
The 04 bed geometry is identical. The taillights interchange but have their own harness that plugs in under the bed in the center rear. I have 07 s in my 99. If you don't have the newer harness you need to notch the twist lock hole to use the older harness. I did that. 1 less bulb than the newer but insignificant small bulb
  • 4 months later...
Definitely not identical.  Body lines are noticeably different, would also expect the frame mounting points and the overall width and length to be at least a little different as well,
As for close enough to make work, that depends entirely on your fabbing skills and what you will find acceptable.
  • 3 months later...
  • 4 months later...
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
