Surprise, surprise. The dealer is claiming that the noise is "normal" and will not be making any repairs, even after the tech rode with me and stated that it was indeed NOT normal. Needless to say I'll be complaining lol... and it looks like I'll be strapping that valve down in the meantime.
The ticking in V4 mode is finally gone!
The tech determined it was caused by either a deffective or inproperly installed steering column seal. (Also called the stearing shaft boot)
Send me a message if you have any questions or if you want me to recomend a dealer in the Richmond area.
So in other words when they fixed the seal the ticking noise is not getting into the Cab anymore.
Well, id like to fix it, but i had a nightmare experience the lasr time i took it in... They dented the hell out of my truck both inside and out, and were completely slack on many other things. As a result they had my truck 50+ days. I love my truck otherwise but i doubt i will ever purchase a chevy again after having these experiences.
  • 11 months later...
That is correct. Apparently the noise is normal....its just not normal to hear it in the cab.
Are you still satisfied with the steering shaft seal repair to solve the ticking V4 noise? I've had mine in multiple times and it's getting very frustrating! New fuel pump, new AFM lifters, and nothing fixes it.
I'm afraid not. They are very friendly and have replaced the steering shaft boot twice and it fixes the problem for a few months then comes back. I have to take it in for recall stuff so I will ask them to take another look at it. I am getting very frustrated.....I also can't stand the clunking spastic transmission, whistling driviers side window, and now the peeling undercoating with rust.
This will be my last new GM. The older ones seemed like they were higher quality.
  • 3 years later...
Any fix? Mines a 2018 5.3 and when in v4 mode with slight acceleration sounds like a card in a bikes spokes as we did as kids sort of flapping...also does it when it kicks into v8 but not as loud
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 267 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
