Looks like they sit about level with the lower lip of the valence? Correct me if I am looking at that wrong lol. I would love to grab a Fisher plow but worry about the ground clearance of the push plates.
They are even with the slightly elevated part of the lip,however,I did install a 2.25 ReadyLift level kit. As they appear now the lowest part of the mount is 12.5 inches from the ground. My plow installer said the level kit was not needed for this install,I leveled for looks.
have you plowed with this set up yet? Im debating getting one for my silverado but if it came down to plow or level i would go with the level
Quick update, Truck plowing well have a lot of snow this week been plowing all week,8 to 12 inches at a time medium to light in weight. I will say its the quietest plow truck I have owned so far good plow truck
I thought the 1/2 tons were not set up to plow? Is there a plow prep package you have on your truck?
Something about the EPAS steering not good with the towing equipment?
no special prep my dealer installs Fisher SD plows on several half ton truck every season,they said no problem. Warranty can be disallowed for many reasons including plows and almost any chassis/susp mods,I hope for the best
Chevy only recommends to plow with a regular cab and you can purchase a snow plow prep package for the truck. This is as follows:
SNOW PLOW PREP PACKAGE includes power feed for backup and roof emergency light, (KW7) 170-amp alternator, forward lamp wiring harness, (TRW) Provision for cab roof mounted lamp/beacon, (K47) high-capacity air cleaner, (NZZ) underbody shield and Heavy Duty Front Springs. VYU not available with 20" wheels without Z71 suspension. (Only available on 4WD models.) (VYU)
(Includes (G80) locking rear differential.) (Z82)
Edited by PMattras
On a 1500, it provides a 3950 FGAWR.
and GM rates it for 40lb maximum of permanently attached snow plow mounting hardware and 500 lbs maximum of removable snow plow blade and blade hardware. Maximum plow weights based on a vehicle with average manufacturer option content and 150lbs each for driver and one additional front seat occupant. Additional equipment and occupants can reduce maximum plow weight. Rear compensating weight may be required to maintain front axle weight below 65% of total vehicle weight when equipped with snow plow, consult your snow plow manufacturer for specific compensating weight recommendation.
(HD's are rated for about 100/1000 permanent/removable weight)
  • 7 months later...
ok im thinking of doing a 3.5" lift on my truck because one I hate how low it sits and two for more clearance for when I put the plow on I have a 7.5 fisher sd and I had it on my 2012 with 1.5 level and a two inch block in the rear should I have any issues when I go to my fisher dealer to have hardware and wiring installed or issues hooking up? Im looking to get around the same height as my other truck if not a little bigger
Edited by Star1018
  • 3 months later...
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
