It will cost less than 1k. I love my 6.2L but i can't leave things alone i put a 2" leveling kit and 33" tires didn't really affect performance to much, but would like to get a little extra power. I will do the maintenance myself with a few buddies so only paying for parts and beer.
Do you have previous experience with changing gears? It's a pretty involved process. I've been around it enough to know that it's something left to a professional, haha. And, you're figuring the cost of a tune into your budget, right?
Have you priced them through GM yet? Last time I checked just a Ring an Pinion from the GM dealership was north of 800$ and you are going to need 2 plus the shim kits, crush sleeve, pinion seal and nut at the least. Bearings should all be good still. As far as I know no one makes an aftermarket set for 9.76".
Edit. The front you can go aftermarket for around 350; it is same as previous years.
Edited by CAtaylor
  • 3 weeks later...
Are their any visual differences we could look for? Some of you guys with post some pics and if you have max tow and 6.2 or 5.3????
But according to the response... all 6.2 and only the 5.3 with max tow.
  • 1 month later...
Here is the axle/differential under my 6.2 with 3.42 gears.
Edited by DCOX
  • 5 weeks later...
Thanks for posting the pic. Unless they look identical, that's the 9.5" rear end. Mine looks exactly the same (also a 2014 6.2 3.42).
Could somebody with the NHT package post a pic of what the 9.76" looks like?
I think you (and I) have the 9.76 axle... I talked to a product rep from Detroit. They said all the 6.2s had 9.76. Not sure of the difference in looks of the 9.76 and the 9.5. More pics would be great.
Edited by DCOX
Yeah, we need pics of a confirmed NHT 3.73 axle. There may have been a change from '14 to '15 as well.
This is interesting I was just under mine and I have a 6.2l 3.73 with NHT. I know I have the 9.76 it was on my build sheet. I was looking because I wanted a new differential cover from PML.
Differential is marked with:
0134
R9652
12 bolt
I have looked high and low for a differential cover without success.
Edited by sugarjohnson
I suspect the 9.76 and 9.5 are one and the same with exception of the ring/pinion set. AAM manufactures the axle assembly for GM, on it's website it lists the same carrier #40090728 for both 9.5 (3.42/3.73/4.10) and 9.76 (3.23/3.42/3.73). Both axle assemblies use the same pinion seal. Gear sets are different part numbers though. Just a guess, the 9.76 is using a HD gear set with a slightly wider tooth on the ring gear to increase contact area.
Wow, so they do look exactly the same. Given all the advertising of the 9.76" GM does I was sort of thinking it would be a beefier housing, maybe larger axles, etc. But if the housing is the same, carriers are the same, bearings are the same, etc, it's really not all that much of an upgrade.
Either way I think this is good news for those looking to swap gears as I would assume the 4.10's AAM now makes should work in either axle. Hopefully anyway.
2011 6.2 with NHT was 9.5". Are you getting confused with year. Maybe the new ones have 9.76" and pre-2014 has 9.5"?
Could have been a change for 15 to handle the lower gear ratios (higher driveshaft torque) behind the 8 speed.
  • 1 month later...
Don't have a pic of it, but on the web from the pinion to the axle tube on pass side it will say 9.50 or 9.76 in the casting.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,276 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
