Haha, if it gets any more complicated I am going to have to start working for GM just so I can get the inside track.
Oh it's nuts and then throw in automotive Ethernet lol
Yup. There was a vendor out there telling people they needed BCM programming because they couldn't do what we do and that was their out LOL 100% Plug and play with our custom programming and not to toot our own horn (because this gets asked frequently) but yes we are the only place that does this (for dealers and customers all over the world :))
Not to mention the poor guy from mexico has a locked odometer too :(
Thanks for squaring that up, I was misinformed, sorry for the bad information. Chris, so if I purchased a new cluster from ebay like this one I can mail it to you and you can re-program it for my truck? What information do you need from me? Currently I have a monochrome gauge cluster and would like a new one like the link above.
yes after we confirm it's the correct part number :)
Okay, let's do it.
The part # for that cluster is 23448517
My truck VIN is 3GCPCPEC2EG460703
Are the clusters for all of 2015 the same expect for the 2500. I'm considering buying a cluster from a September 2015 build and my truck is a December 2014 build. Both 1500 2015 trucks. I know there is a 2015.5 but is that just on the 2015 2500s.
Edited by sierraguy2015
Okay, let's do it.
This tied with the steering wheel controls is well worth the upgrade. I assure you.
Edited by Darth_Vader
no they are different please contact us from our website and we can work through part numbers with you.
Awesome to hear that. I already have the new steering wheel with controls/heat. I figured, if I'm changing the steering I might as well swap out the boring monochrome cluster.
110%
110%
Hey Chris, I'm about to order the gauge cluster. Should I have it shipped directly to you?
Hey bud, did you buy any of the wire terminals for the plugs? If so, where did you buy them?
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
