Looking good bro, I have the same truck, took off the h/c emblems, and 4x4 stickers. Debating on going with black handles, and mirror caps.
I'm probably gonna strip everything and keep the chrome mirror caps and door handles
Looks good! So what's next with this "I'm going to leave it stock" plan?
Lol I know I know, I may have lied a bit. I was thinking of getting a 30" light bar and mounting it behind the grille. Hook it up with a wireless remote like a lot of guys have been doing.
Also want to get my HID's put back in. I realized I had them hooked up wrong after I got rid of them, so I'm gonna give them another shot.
Plan on doing some lights in the bumper steps, lights out back for hooking up a trailer, and probably some floorboard lighting.
I've thought about an auxiliary battery as well (side post for this one), some kind of CAI or maybe just an AIRAID tube.
I've also looked at exhausts and found a Gibson exhaust I liked, but Chris is telling me go Borla. I like the Gibson because another member has one installed and said it's a tad louder than stock going down the highway, but nothing too bad and he said it sounds good when you get on it as well. Still undecided
And of course I want to do a catch can. This will probably be my next mod
Edited by rdnckhntr94
Sounds a bit pricey lol. I was planning the catch can myself but I've come to realize it may be to late to make a difference
It will take a while before everything gets done. Small stuff like accent lighting is cheap and easy.
Right now I'm getting my quad ready for a trip to Hatfield-McCoy's sometime in May. Gotta do an oil change, diff fluid changes, wanna install a light bar, and maybe do some better tires
Got the catch can installed today! Took about an hour once I had all the supplies together and then fabbed up a bracket for the can. Used 3/8" trans line like others have suggested but I still get a suction sound like others have reported. It's nothing I can't live with. Here's some pics
Got my step lights in from oznium.com!
Whenever I have a couple hours to spare (maybe tomorrow afternoon) Im going to remove the rear bumper so I can drill my bumper steps for the LED bolts. The steps are attached in weird areas and removing the bumper aint hard to do. Hopefully she'll be all lit up out back here soon. Want to also hookup a couple other LED bolts I purchased and somehow fab up a bracket and mount them to my draw bar so it makes hooking up a trailer in the dark easier.
UPDATE: catch can is doing a helluva good job. Ridiculous the amount of oil that is in it after only a thousand miles
Can't wait to see the results! Mind letting us know how to remove the rear bumper when you do it? Just for those who go to do the same lights as you and for those like me who want to spray line the black plastic on the bumper [emoji1]
Looked at it today. Real easy. Looks like 10 bolts with a T45 torx head to remove em. Undo the sensor on the distribution box and remove tag lights. Seems like it will slide right off. Shouldn't take me but 10 min.
Oh yeah looks like for easier access you can drop the spare tire, but that's not necessary I'm sure
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
