1997 sierra control panel lights out
In my 1997 sierra all lights work except the radio lights (clock works) and the heater control lights! Is this a headlight switch problem or is there something else that would cause those to go out? I've checked all fuses
Thanks
Check ALL fuses on drivers side dash of course. Heater / ac control lights are easy to change out just pull off dash trim for access. Radio lights require disassembling the radio. I just purchased a like new OEM Delco cd player and pac aux adapter for my iPhone input.
Ive checked all fuses, and I'm pretty sure that many light bulbs are not going to go out at the same time! You have to have extremely bad luck if that happens! And again radio works great, clock works, heater works just no lights at all on that side of the dash except the clock!
I have to turn the dome light on to change a radio station, or ajust the heater!
There has to be a wire in there not good or something else!
All the other lights work, guages, 4x4, ONLY the lights on the radio and hearer control!!!!
  • 3 weeks later...
First picture is my wifes 97 yukon, the second is my 97 sierra
Now I know all the bulbs are not going to go out at the same time
There has to be a wire to check, or the healight switch (that happened in
A jeep cherokee once) but I don't know that s why I'm asking
Hoping someone else has had the problem!
  • 8 months later...
Just put another headlight assembly in from another 97 sierra and made sure all the lights worked in it before I switched them over! I took the headlight switch and the stereo out of it and put it in mine and still have the same problem!
All I can think now is somewhere between the switch and both stereo and heater control there is a bad wire just which one?? Lol
