02suburbanZ71 Posted December 31, 2014 Posted December 31, 2014 Im just curious on what it would take to swap an 02 2500 HD transfer case into an 02 1500 auto trac. Im not a big fan of auto 4 anyways
newdude Posted December 31, 2014 Posted December 31, 2014 Not sure if input splines for transfer case match between the two (that is if 4L60 and 4L80 have different output shaft splines). Also, being non-auto trac, the switches are different, transfer case control modules are different, encodor motors are most likely different which in turn the wiring and connector ends are most likely different as well.
02suburbanZ71 Posted December 31, 2014 Author Posted December 31, 2014 I know the splines dont match but thats about all i know lol.
Chris Posted December 31, 2014 Posted December 31, 2014 A ton of wiring, switch, tccm, shafts, and finding someone willing to program it
02suburbanZ71 Posted December 31, 2014 Author Posted December 31, 2014 Switch would be easy to swap, custom shaft, pull a TCCM from a totaled 02 2500, pay the dealer to flash it. I guess the hardest part would be the connectors i guess i would need a new harness to the pcm
kstruckcountry Posted December 31, 2014 Posted December 31, 2014 Tons of wiring would be needed, they use a different TCCM I believe. The 246 is a good box, no reason to change.
02suburbanZ71 Posted December 31, 2014 Author Posted December 31, 2014 Tons of wiring would be needed, they use a different TCCM I believe. The 246 is a good box, no reason to change. Okay i just wanted to get as close to an HD powertrain wise as possible
DanMan_S Posted January 1, 2015 Posted January 1, 2015 Okay i just wanted to get as close to an HD powertrain wise as possible Easiest/cheapest way in that case is to probably just buy the HD truck.
02suburbanZ71 Posted January 1, 2015 Author Posted January 1, 2015 I have no intention to sell the vehicle.
gmtech4 Posted January 1, 2015 Posted January 1, 2015 I have no intention to sell the vehicle. Ok , keep the truck but sell that dam Marquis !!!!! Lmao !!!!!
02suburbanZ71 Posted January 1, 2015 Author Posted January 1, 2015 Ok , keep the truck but sell that dam Marquis !!!!! Lmao !!!!! I couldnt! my grandpa died and left it in his will. Way to much sentimental value and memories. If anything it'll be the pos equinox LOL
gmtech4 Posted January 1, 2015 Posted January 1, 2015 I couldnt! my grandpa died and left it in his will. Way to much sentimental value and memories. If anything it'll be the pos equinox LOL I understand about the Ford , Yes , crush the Equinox !!!!!! Hard , crush it hard , !!!!! Lol
gmtech4 Posted January 1, 2015 Posted January 1, 2015 I thought you loved crossovers Rob! Lol I have a RAV4 sport , so I guess I do , just don't like the equinox name , easy to work on thou
KMGZ400 Posted January 1, 2015 Posted January 1, 2015 Out of curiosity why would you want the bigger t-case? And having auto 4wd is definatley a benefit over the 2500's which dont
