Best Bed Mat and Tailgate Mat?
Hi All,
I just purchased a new 2015 Silverado double cab and want to purchase a bed and tailgate mat so I am looking for suggestions and recommendations.
Thanks, Jersey Guy
JG
I've always bought the heavy black rubber mats sold by my camper dealer. I have no idea what brand they are. Keep in mind that anything you add to the tailgate will cause the tailgate to drop harder.
For a grand total of $130 I went with the DeeZee bed mat and WeatherTech tailgate mat. Ordered off Amazon.
I have a Dee Zee rubber mat that I moved from an '03 to a '13. It's just some kind if 1/4" thick or so piece of rubber (or something like rubber) that has reinforcing string of some kind in the rubber. It's made or fit around the wheel wells and pretty much covers up the bottom of the bed. It'll last forever and is pretty heavy to move in and out. I rarely take it out. As for the tailgate, I ended up using a hard plastic cover (can't remember the brand) that has to screw on. I need to be able to slide stuff on the tailgate so a rubber mat wouldn't work for me there.
Mike
I have a DeeZee rubber bed mat in my truck and it is great and I only paid $65 total shipped to my house for it. No issues.
I got the factory GM one off of Amazon for $100. This mat is thicker and heavier than an aftermarket one that I had in my other pickup. It also is more tacky than the old one so things don't slide around on it. I have the hard plastic bed liner on the tailgate. It allows things to slide into the box easier and I got it for free.
I have the thick rubber liner from my 13 and it fits fine.
I bought the WeatherTech tailgate protector and it's a piece of junk.
I got the GM bed mat & tailgate liner as part of the deal when I bought my 2014 Double Cab.
Tailgate Liner Part# : 22879304
Black Rubber Mat, GM Logo, 6'6" Part# : 17803371
http://www.amazon.com/gp/product/B000VU7NL8/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
look below the product where it says "frequently bought together" you will see both for $98
Thanks everyone for your comments. I ordered the same GM parts that Vmax08 stated above. I found them both on Amazon for a good price.
oops just noticed you already ordered....
i have the new weather tech that velcros in and goes three inches up the sides of the bed for liquids and such. i love it!
For those with bed mats, do you also have a bed liner too? Sorry for the newby question, but this is my first truck. Thanks :P
I just have a bed mat with no liner, but I have seen lots of trucks with both. Some people like the mats because things tend to not slide around so much.
I just use a garden hose and squirt out the bed. The rubber bed mat keeps things from sliding around. I actually took a big bed mat and screwed it to the (gun) bed drawers I have.
BedRug with the GM bedmat on top of it.
The Bedrug covers the whole bed plus the tailgate. The GM Bedmat prevents the bedrug from getting muddy.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
