Ok finally got it opened up. I removed one of the wires to look at them side by side. 6d82fcdb94a9f41ad7b8193a22e77a0b.jpgf713381bfc630ccae5d9a391dd36aafd.jpg
They look the exact same. Only a slight variation on the clip but they should fit just fine.
That's awesome! Nice find!
Azelkhunter do you actually have adjustable pedals? I don't and was wanting to use them as my fourth switch. Only problem I see is one pin moves pedals up and another moves them down. Should I tap both wires and bring both to the latching relay? Lane departure and park assist aught to be strait forward. I'm right there with you on the exhaust brakes though. Mine had the harness as well which was a pleasant surprise.
I do have the adjustable pedals, which was one of the main reasons I didn't use the upfitter switch. You could easily use this switch to control two devices, which is pretty cool. Up could control one relay and down could control a second.
Ok so I said that park assist and lane departure should be straight forward. But I looked at the pin list some more and there are 2 pins for these also. Do pins 5 and 6 control the led light on the front of the switch? Did you get yours working?
My indicator lights do work, I just had to connect the output to my relay to the indicator light pins (since I am sending a low input to my relays).
The pins are as follows:
Pin 1 - Illumination +
Pin 2 - Indicator lights +
Pin 4 - Downhill Assist switch -
Pin 5 - Lane Deprture Indicator -
Pin 6 - Park Assist Indicator -
Pin 7 - Cargo Light Indicator -
Pin 8 - Lane Departure Switch -
Pin 9 - Park Assist Switch -
Pin 14 - Ground (this is the ground that is provided by each switch)
Pin 15 - Power Seat ->
Pin 16 - Power Seat <-
Pin 17 - Traction Control Switch -
Pin 18 - Cargo Light Switch -
Thanks. That helps out. I am just going to tie the pedal up and down together as the switch for that button. That sounds reasonable. It won't have an indicator but I plan on using it for RGB halos that I want on all the time. But I still want the capability to turn them off. I will use the NO function on the latching relay and the button push will turn them off.
Nice! You definitely don't need the indicator light of they are going to be on all the time.
Here are is a pic with my indicator lights on. post-153411-0-60711100-1458252964_thumb.jpeg
Looks good. You got your second set of relays yet? Also what did you use to sand off just the center of the button. I haven't done mine yet. I'm going to get it all installed and working and the go back and do them.
Edited by arkiehou02
I have 3 latching relays installed in the little module that I made. I am currently running two relays from those, 1 to a light bar and the other to spot lights mounted in the grill. I have one spare latch for the next accessory I find. Haha. Thinking compressor or something along those lines.
I used 400 grit sand paper, I am impatient though. You can use 800 grit and possibly save the white under, but it takes a lot longer than I want to spend on it. Maybe a 600 grit compromise would be decent. 400 works for sure. I wrapped the sand paper around the tip of a screw driver for better accuracy.
Edited by AZelkhunter
After reading this thread from to back a couple times, i have a couple questions.
I ordered the switch panel 23145202 (Pedals / TC / Dome Light / Park Assist / LDW / HDC / Exhaust Brake) with plans to use LDW and Exhaust break for the aux buttons as i am using the others on my '15 Denali.
That being said, do i need latching relays or will regular automotive relays work?
At this point, i only have one light bar and plan on it going to LDW but want to hook up the EB switch and wire so i dont have to pull apart the dash again.
Will the lights work on the switches with the current wiring or will i have to add those pins? Looks like pin 5 is the LDW indicator and pin 8 is the switch. Assuming same answer for the EB as well with whatever corresponding pins?
Here's the colors I used and what the pins outs are. The numbers are the pin out from the diagram.
blue= pin 12(aux#1)
white= pin 13(aux#2)
green= pin 11(aux#3)
yellow= pin 10(aux#4)
Blue is aux 1
White is aux 2
Green is aux 3
Yellow us aux 4
Edited by EQUIS24X
Here's a video of everything working.
Edited by EQUIS24X
You will need the latching relays and most likely regular relays. The latching relays maybe fine to run them but I think the consensus was to use the latching relay to switch a regular relay. Thus leaving the majority of the current going through regular relay.
You will need do add wires to the plug. Yes, you will need the pins from the lights on the switches (indicator) tied into the NC pin on the latching relay. The pins I used in the earlier post do work.
I have not been able to figure the pin config on the EB as of yet. I believe there was 5 wires in the plug. I assume one is for the indicator and one is the positive. It I don't know either if it requires another ground out is tied to the other pins going internally. If you figure any of this out please share.
Ok time for a little update. I know I am incredibly slow and apologize for that.
So I ordered this relay from eBay for around $4 thinking it would be the same. Not so much! It turns out this was not a latching relay.
So then I went back to the drawing board. I just knew I could find a 4 channel latching relay and I finally came across one from Amazon, and it was even on prime. d00614f3351b611b78187d4553987d07.jpg
I got everything hooked up and each of the first 3 relays trigger with the pedal button, park assist button, and lane departure button. For the Pedal button I ended up putting the pedal up and pedal down wires into the trigger hookup. I don't have a picture but I got everything in a small plastic case and added my ground wires to the output so the indicator lights work as well.
fdd0a656a4ab9c3a671bc4686a5df5c7.jpgUp next is getting my relay box wired and mounted under the hood. I bought this box from Amazon. I plan on using the 2 additional relays to turn the headlights off and just have some rgb halos as daytime running lights.
I ended up opening up the switch housing today and saw the momentary switches. I ordered the latching relays off eBay and will play the waiting game. I have a pin breakout for the EB that I got from one of the PDFs posted so I have a good start except the indicator. I plan to mount everything in a battery box in the aux battery pan.
Cab you post I picture of the pdf or a link? I haven't been able to find anything on the EB.
Pin outs in the PDF. Let me know what you find out.
EB.pdf
EB.pdf
EB.pdf
EB.pdf
Thanks. I posed a question about it on the HD section. I would say connect pin 4 to the trigger and pin 5 to the NC output to control the indicator light. The only thing I am confused on is how the power takeoff would function. And I need someone with the EB to answer that.
Someone just said: push button it turns on, push again it turns off. So I would say it is just pins 4 and 5.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
