You connect the wiring harness like you would normally do. When your done, program your homelink with the remote it comes with. Just like your programming a garage door opener. To be honest, Id rather have a switch hard wired. While driving I have to press the button a few times before the lightbar turns on.
Thanks for the input man
I found this terminal. It looks the same as the one on the wire part. Anyone got any thoughts on this?
I don't know that it fits but I think I'm going to start here before I drop $40 plus for the gm oem.
https://www.ecstuning.com/ES2207797/?gclid=CjwKEAiAuKy1BRCY5bTuvPeopXcSJAAq4OVsa9DpOT2Xamn5FeFI3J3Eqa0ykQkEdR4fbFn81vJa4RoC9C7w_wcB
EDIT: Found them cheaper here: http://www.digikey.com/product-detail/en/962885-1/A105237CT-ND/3440492
I ordered them. I will post a follow up when I check the fit.
Edited by arkiehou02
  • Like 3
They look very similar, hopefully they will work!
any updates on this?
I did get them in and they look similar. I am still waiting on lights and my new switch before I dig into the dash thought. I will look tonight and see if there is a similar plug visible somewhere else.
Did you ever get this installed?
It's still a no. I have lights but I'm still waiting on the switch and latching relays. The switch will be here next week but the relays are coming from China. I will try and break into the dash when the switch comes in. I need to look for a spot door the latching relays anyway.
  • 3 weeks later...
I just posted this on colton_m's original post...
I think that I have found a solution for using the OEM Momentary switches to control accessories such as light bars. I have decided to use the 23145202 switch as I have the adjustable pedals. This switch gives me 3 open slots to use. The issue with the switches is that being momentary they will not operate a standard relay. Upon searching I found these latching relay boards that come from China and cost $3 each. I picked up four of them to try, they are 12V boards that use a low input, so when the input is grounded, the relay activates and latches, until the input received another low signal. I assembled 3 of them in a case made a harness for them.attachicon.gifimage.jpeg
I am modifying the switch to have the correct icon too. attachicon.gifimage.jpeg
This looks great -- nice work!
Where did you get the stickers?
My wife cut them using her vinyl cutter.
So I started installing everything yesterday and discovered that my truck has the 2nd harness for the exhaust brake port, even though the original switch has a blank port. I think this could be a good thing and maybe I can just add a fuse/relay and utilize existing hardware in the truck. At the very least I now have wires to tap into for that last switch. Anyone have schematics for the exhaust brake?
I also took pictures of the main connector to see if we can find the connector and the correct pins. post-153411-0-84163900-1457627051_thumb.jpeg
I also took pictures of the main connector to see if we can find the connector and the correct pins. image.jpeg
That's interesting that the connector was there even though it was a blank. The wires were there too? I wonder where they leed?
I would think once hooked up you could just ground one wire and test with one of the latching relays. Just use the process of elimination.
I don't really understand why the connector has so many pins. The exhaust brake is not a variable thing is it? (Multiple presses don't mean different things do they?)
On a side note, I am about ready to crack mine open too. I don't have all my lights in yet but I got a box with 6 relay ports so I can just run all my wires and be ready for lights as they come in.
So did you just add wires to all of the pins in the exhaust brake connector. That's interesting that the connector was there even though it was a blank.
I didn't add any wires to the brake controller connection, it is a complete harness. That's why I am thinking I can just find the stock relay location and utilize the OEM wiring, instead of taping into the wires at the plug. But if not then I will use wire taps and connect my switch trigger to the switch output and then my output to the relay will connect to the indicator ground.
I have everything connected and it all works great! I will have to modify the schematic just to show that the low output from my latching relays is also run to the switch for the indicator lights, so I used two wires for each switch. I have a video that I will try to post later. Everything works just like it would from the factory. Here are a few pics of the wiring while I was installing.
post-153411-0-59264900-1458156453_thumb.jpeg module mounted under steering wheel
post-153411-0-10790100-1458156466_thumb.jpeg harness to power/ground and relays
post-153411-0-34581700-1458156499_thumb.jpeg harness showing plug for module and wires to OEM connector
post-153411-0-62086000-1458156483_thumb.jpeg switch installed
Ok finally got it opened up. I removed one of the wires to look at them side by side.
They look the exact same. Only a slight variation on the clip but they should fit just fine.
Azelkhunter do you actually have adjustable pedals? I don't and was wanting to use them as my fourth switch. Only problem I see is one pin moves pedals up and another moves them down. Should I tap both wires and bring both to the latching relay? Lane departure and park assist aught to be strait forward. I'm right there with you on the exhaust brakes though. Mine had the harness as well which was a pleasant surprise.
Ok so I said that park assist and lane departure should be straight forward. But I looked at the pin list some more and there are 2 pins for these also. Do pins 5 and 6 control the led light on the front of the switch? Did you get yours working?
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
