42 minutes ago, Hunter Webber said:
These oem aux switches are a on-off only right is there any that are a momentary to use for a air horn?
No. But I open mine up and was able to make one to do momentary
Ok thank you
Would like to share some pictures of where I ended up putting my aux switches at. I have one before picture. The rest is after. I didn’t like the idea of the switches being low on the knee panel.
so I will be rewiring and hardwiring the full kit in. Cause this kit is really made for 2019 and up. My truck is a 2017 2500hd Denali diesel. So all my factory uplifted switches are spoken for all factory features.
On 4/22/2018 at 5:07 PM, TinkeringFox said:
Hi there, I’ve been working on a comprehensive video on all of this with part numbers and explanations, diagrams etc. you have a few options that are pretty easy since you don’t have adjustable pedals. I just got my new X50A (under hood fuse box) in the mail and found a new relay for a second fuel pump. The reason I bought it was for the four AUX/Upfitter relays. This would be perfect for your application. If you can hang in there a few more weeks I’ll have everything complete and post the video.
Tinkeringfox, did you ever post a youtube video on this (as referenced above?) thanks..
Hello. I’m a new guy here in the forum. I have a 2015 and a 2016 Silverado 1500 WT’s. I am installing a dual battery system to run a power sprayer rig setting in the bed, and I am looking to install the GM switch with 4 auxiliary switches to turn power on and off to the sprayer. I noticed that the J block behind the parking brake pedal for the switches is not there, but there are flat pins sticking up from where it would be. Probably a silly question but I’m a novice at this stuff, but does that mean if I get the J block the wiring for the J block is already there to the respective relays, etc.? Or would I have to run the wires through to the relays and fuse boxes? I know the wires from the J block to the switches come with it.
 Thanks in advance.
  • 3 months later...
On 11/9/2018 at 1:10 PM, tckirkpa said:
OK.  got a few switch banks and combined switches to match my options.  Now I've got to pin out the connector to figure out what's what.  Once I know which pins cover which functions I'll be able to hook everything up correctly.  It was a real nightmare getting the switches out of the housing.  My final configuration is all momentary switched with a board from GM part number 23145202.  It originally had pedals, stability, cargo lights, park assist, lane keep, hill assist, and exhaust brake.  I don't have lane keep, hill assist or exhaust brake as options on my truck, so I replaced those with three aux switches.  I think it's going to be a bit of work to figure out the pin outs.  It looks like every version varies some, but I'm hoping that there's some commonality at least with the options I do have.  That way those items should work just like before when i plug in the new switch bank.  I just have to figure out which pins go to the other three switches now and if there are led returns.  I know the exhaust brake is going to be on the smaller connector on the back, so it's just aux 1 and 2 I need to identify.
I'm hoping the pin out looks like this
Pin function Note
LED Backlight Dimming Control
2
LED Indicator Lights Dimming control
I hope this powers the indicator LEDs on the three aux switches too
3
I'm hopoin this is signal for Aux 2
4
or this is the signal for aux 2
5
I hope this is the lane keeper led signal
which is now aux 1 switch
6
rear park assist LED disable
7
not sure
8
I hope this is aux 1 signal
9
park assist disable signal
10
not used - upfitter
11
not used - upfitter
12
not used - upfitter
13
not used - upfitter
14
ground
15
adjustable pedals rearward signal
16
adjustable pedals forward signal
17
traction control signal
18
cargo lamp signal
  and for the exhasut brake connector
1 PTO - not used
2
PTO - not used
3
Run/crank Ignition - not used
4
Exhaust brake LED now my Aux 3
5
Exhaust brake signal now my aux 3
6
not used
I have the same switch layout with pedal adjustment, traction controll,cargo lights and park assist and I want to add 3 aux switches. I know I need to order another switch set and combine them but do I need to order any other wiring harnesses or anything else to make this work?
  • 3 months later...
Just Courious but does anyone have any experience with a Nilight 6 gang Switch panel comes with its own little fuse block as well.
Nilight 6 Gang Switch Panel Car Circuit Control Relay System with Fuse and Wiring Harness Automatic Dimmable ON-Off LED Switch Pod with Label Stickers for Cars Trucks Boats ATV UTV SUV
Not personally, but a buddy of mine installed one.  He likes it.  Hardest part was feeding the cable through the firewall into the cab.  Most of the wiring is done for you, which is REALLY nice.  No wire crimping, if you don't want to do it.
I Just completed a breakdown of the switch bank. I have a 2016 1500 Z71 with the three switch panel, TCS, Bed Light, Hill Descent Control. I bought two additional switch banks and opened them to create one that would work for me. Now I have one working bank with TCS, Bed, Light, Hill Descent control, and 4 aux switches.
Was it hard to do?
On 12/30/2022 at 1:56 PM, Rock1500 said:
Was it hard to do?
@rock1500 It took a bit of work to get them disassembled and put back together. If anyone is interested they can shoot me a PM and I would be happy to look into what it would cost to do. I wasn't sure if there would be a market for it. There is some soldering and de-soldering of some micro components to make it work like it should.
Heck, if you can replicate this on a regular basis, I'd buy it in a heartbeat!
@MikeBMW
Are you looking for the same set up I had. Convert from the three switch to the seven switch? I had tcs, bed lights, hill decent and converted it to those three with 4 aux switches?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
