Newbie Looking for Advice
Machspeed
Hello Friends,
New here from Northeast Oklahoma and a Ford convert. I've had good luck with Fords and admittedly I am a diehard blue oval fan. However, I just do not like the looks of the new F150. To me, the Chevy Silverado is flat out gorgeous, thus my intentions to purchase a brand new 2015 later this year. It will be for casual use but I will, from time to time, need to pull a 20 ft trailer loaded with my 69 Mustang. What I do know is that I want the double cab standard box LTZ Z71 powered by the 5.3L engine. This configuration can be either 2 or 4wd and I’m not sure I want or need the 4wd. That said, and knowing what I will be using the truck for, how would you option out the truck? Also, what is typically the best time of the year to acquire a new vehicle from GM? Anything you regret in the purchase of your vehicle that might apply to me and my needs and intentions?
Thanks!!!
For OK I doubt you need 4wd. Be sure to compare double cab to crew cab, make sure you can live with the small rear doors of the double cab. I would want the 6.2 (but that's want, NOT need). Be sure you gear for towing at least 3.73s. Get any and all towing options/coolers, get the factory brake controller for a trailer. Best time to buy is model change, old going out new coming in. I think last year it was "black Friday"
Welcome, what's your location. If you ever run into slippery, muddy, or off road conditions I'd opt for the 4wd. As to towing, I'd get the lowest gearing (numerically higher) possible. 3.42s will work good, 3.73s would be great.
I agree, go with the 6.2 & 3.73's...
I have no issues with the Double Cab.. I had no choice the Crew Cab with the standard box was to long for the garage.
The 5.3 with a 3.42 is getting the job done... towing. Camper, Horse trailer.
Working so well we are shopping for a bigger camper....
Hey thanks, fellas. I'm well aware of the troubles in towing capacity with the 5.3 and the 3.08 gearing, but thanks on those points. Am considering now the 6.2, as the mpg ratings do not appear to be much different than the 5.3. Can anyone confirm? And, well, I'm really struggling with a color choice....LOL.....Deep Ruby vs. Deep Ocean Blue vs. Silver Ice Metallic. Ohhhhh the decisions!
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
