Pictures won't post properly. But heres the rest. Installation Instructions Part Number
22901614
Kit Usage
This kit adds remote start to vehicles without option BTV. The vehicle must also have AQQ and an Automatic Transmission. Both can be verified by using GM Vehicle Inquiry System (GMVIS). For proper operation of the remote vehicle start system, a hood status-switch equipped hood latch is required. For light duty trucks, a jumper harness addition is also required in order to complete circuit 109, Hood Status Signal to the Body Control Module. Adding remote vehicle start also requires programming of the vehicle. This is done using the Service Programming System. The installer must call TCSC (1-888-337-1010) to obtain a VCI number. The TCSC will provide a Vehicle Configuration Index (VCI). The VCI is good for only one specific Vehicle Identification Number (VIN). You must have the vehicle’s VIN that will be upgraded and the Authorization Code from the label on the Installation Instruction Sheet included with the kit. This will allow you to access the software to enable the remote vehicle start option.
Kit Contents
Qty
Description
Set of Transmitter Key Fobs (2 in total)
Hood Latch Assembly (with switch pigtail)
Jumper Harness Assembly, including strap clip attached with blue tape (Light Duty kits ONLY)
10
Tie Straps (Light Duty kits ONLY)
Installation Instructions (including Authorization Code Label)
Note: Due to wire routing requirements on Light Duty Pickups, please review this entire procedure before trying to perform it.
Note: When calling the TCSC, you must use the Authorization Code from the kit and have the VIN available.
Special Tools, Equipment and Chemicals Required
  • Scan Tool (with capability of communicating on GMLAN)
  • Service Programming System (SPS – TIS2WEB, or equivalent)
  • J-46079 Tire Pressure Monitor Diagnostic Tool
  • GM Glass Cleaner or Cleaner-9M905449 (US) or 00992727 (Canada) – or equivalent
  • Silicone RTV 12378479 US or 88861419 Canada – or equivalent
  • 8” (20cm) ¼” diameter steel brake tube with ends cut a 45 degree bevel – for feeding wire through grommet
  • J-38125-22 wiring connector tool
Diagram for LD PU Harness Only
This diagram outlines scope of the Jumper harness for Remote Vehicle Start accessory:
Front of vehicle (1)
Plenum (2)
Plenum Grommet (3)
Harness Ground (4)
Hood Latch (5)
Procedure Remove Front Compartment Front Sight Shield
  1.
  2. Remove the front compartment front sight shield push-in retainers (1).
  3. Remove the front compartment front sight shield (2).
Updating the Hood Latch – Required for all non-UTJ Pickups
Harness is For Light Duty Trucks Only
Route 3-way connector jumper harness branch (2) along front of vehicle, in preparation for routing under Grille Mount Panel Bolt (1) and Bracket (3). Be sure to route in front of air baffle (4). As a general guideline (after driver side of the hood latch) route alongside the Hood Release Cable up to the Driver Side Hood Bumper located on the Tie Bar.
For Light Duty and Heavy Duty Trucks
  1. Remove and replace hood primary and secondary latch. Refer to Hood Primary and Secondary Latch Replacement.
  2.
  3. Make connection from the Hood Latch Pigtail (2) to 3-way forward lamp harness connector (1) (or Jumper Connector for Light Duty Trucks.)
  4. Ensure that the connection is securely fastened in the positioning locator for the connector. Refer to B55 Hood Ajar Switch.
  5. This Step is For Light Duty Trucks ONLY:
    Remove the 6.35mm hole clip with strap, which is taped to the harness (blue tape) and fasten harness (4) to the air Baffle (3) 6.35mm hole approx 4” (10cm) away from connector. Tighten strap clip and cut to length.
  6.
  7. Remove and replace grille mount panel bolt (1).
    Tighten
    Tighten bolt to 25 N.m (18 lb ft).
    Note: Ensure the bolt does not pinch the jumper harness conduit when fastening.
Installation of the Hood Latch Status Signal Jumper Harness (For Light Duty Pickup ONLY)
Routing the 3-way Connector Branch of the Harness (Light Duty Pickup ONLY)
Note: Use a tie strap, part number 11509086 (10 total in kit) to secure the harness to the hood latch release cable, after the hood latch, and before the hood bumper. Cut all tie straps to length.
Fasten the jumper harness to the Hood Latch Release Cable in one location along air baffle, using tie straps (1) P/N 11509086 from the kit. (midway between the two hood cable clips (2). Secure harness along hood release cable using two additional tie straps (3) P/N 11509086. Approx distance between tie straps should be 20cm. Cut all tie straps to length.
Routing the Ground Branch of the Harness (Light Duty Pickup ONLY)
  1.
  2. Route the ground ring branch of the harness along the washer bottle tube and fasten using a tie strap P/N 11509086, to the forward lamp harness head lamp connector branch. Continue to route in front of the bottle and in front of the fog lamp bracket. Accessing from underneath the vehicle, continue to route behind the front fender and fasten to the upper end of the downward branch (2) of the forward lamp harness (1) using tie strap (3) P/N 11509086.
  3.
  4. Continue along down to the ground stud G101 (1). Remove the ground stud and fasten using BOLT/SCREW-FORWARD LAMP WIRING HARNESS GROUND, tighten to 9 N.m for ground ring, noting there may also be an existing ground from the forward lamp harness. Cut all tie straps to length.
Underhood Routing of the Hood Latch Status Signal Wire (Light Duty Pickup ONLY)
  1.
  2. Following hood latch cable, route the signal length of the harness (1), inserting the harness into the C-clips (2), in two locations.
  3. Using tie strap (3), P/N 11509086, fasten in two locations between C-clips, maintaining approximately 20cm between fastening points. Cut tie straps to length.
  4.
  5. Fasten to the third hood latch cable C-clip and branch away and toward the body harness before the grommet (3). Fasten the jumper harness (1) to the body harness using two tie straps (2) P/N 11509086 evenly spaced approximately 20 cm alternating with clips. Cut to length.
  6. Route the signal wire conduit to the body harness grommet, ensuring to create a 3” diameter drip loop (4) before positioning the taped conduit end at the grommet for entry to the interior of the vehicle.
  7. using a utility knife, cut an 1/8” slit in the grommet (3) to prepare the entry for the bare signal wire.
Routing Wire through Grommet to the Body Control Module (Light Duty Pickup ONLY)
  1.
  2. From inside the vehicle, remove the fasteners and position aside the instrument panel wiring harness junction block.
    Note: Junction block connector removal is not required.
  3. Using a utility knife, cut an 1/8” slit in the thin hole of the grommet opposite of the exterior side. From inside the vehicle, insert the ¼” brake tube (2) through the back piece of the grommet (3).
    Note: Grommet removal should not be required.
  4. From inside the vehicle, carefully push the tubing through to the front of the grommet, exiting at the exterior end of grommet.
  5. From the under side of hood, insert and feed the signal wire (1) and terminal through the tubing (2) to the inside of the vehicle.
    Be sure to maintain the conduit drip loop just before the grommet entry. Verify that the grommet end does not collapse.
  6. Remove the steel tubing (2) and clean both the entry and exit surfaces of the grommet using cleaner P/N 9M905449 (US), 00992727 (Canada), or equivalent.
  7. Apply silicone to the grommet at both wire entry and exit, using silicone P/N 12378479 (US), 88861419 (Canada) , or equivalent. Leave to dry while completing the remainder of this procedure.
  8. Using J-38125-22 tool, remove any wiring in K9 BCM X4 26-way connector pin 24 (BN/L-GN) and tape back onto the body harness, if applicable. Insert the GN (green) jumper harness signal wire connector into pin 24 on the K9 BCM X4 26-way connector. Refer to K9 Body Control Module X4. Reinstall all connectors.
  9. Reinstall the instrument panel wiring harness junction block to the floor studs and install the fasteners.
Programming the Vehicle (All Vehicles)
Note: For North America vehicles, the installation of accessory remote start requires BCM programming. This is done with a Service Programming System. The installer needs to call the Techline Customer Support Center (1-800-828-6860). The Techline Customer Support Center will provide programming instructions and changes to the vehicles calibration settings. You must provide the vehicle identification number (VIN) of the vehicle to be programmed and the authorization code provided with the accessory, when calling.
Reprogram BCM. Refer to Body Control Module Programming and Setup and follow Reprogram Control Module Instructions.
Learning Transmitters to Vehicle
Reprogram remote control door lock transmitters. Refer to Remote Control Door Lock Transmitter Learn
Reinstall all removed components.
  • 5 years later...
    • if you want a short turning radius get a short bed Colorado!
    • that is pretty awesome MPG there!  I think so far one observation is these trucks do way better on MPG under 65mph vs 70+ and they really suffer at 75+   I noticed on the stretches into NE on 76 and 80 which is posted 75MPH and I was doing 82 I was getting more like 13.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
