Today got the warning chimes...every few seconds. No warning indicators, open and closed the doors, unbuckled and rebuckled the seatbelts...even checked the passenger sensing (put body in and removed from seat) with no luck. Shut the truck down for 20 minutes and it hasn't repeated.
Not sure where you live, what your weather is like, or if you have park assist. But if you have park assist and the sensors get covered in ice or snow, it will set off the warning chime periodically. Eventually, if snow and ice get too heavy the park assist will shut off and the message will display in info center.
That's a good one because the same thing just happened to me. The chime started sounding every 10 seconds without any message anywhere. I turned off the park assist but that didn't make any difference so I pulled over and stopped.Then the chimes stopped.
As soon as I continued driving it started again and then I noticed that when activating the turn signal, there was no clicking sound, flashing arrow but no sound.
After checking all of my DIC settings and noticing no changes I was at a loss.
Anyway, after I had finished my shopping (about an hour later) and headed back home, everything was normal again.
Go figure.????????????????????
ok, so I am not crazy. I've owned this truck since 12/2013 and have 18k miles on it. Two weeks ago I left the gym, right after start up mine started chiming. I made sure seat belt was clicked in and open and closed the drivers side door. Drove off and then about every 10-15 seconds the chime would go off. No warning on the dash, no gauges out of normal.
I finally stopped and put truck in park, killed the engine and then restarted. It has never done it again.
  • 10 months later...
Did anyone ever figure this out? Happened to me today. 5 random chimes, no indicator light, not the sensors because I shut them off before driving due to ice build up right now, not the seatbelt because I checked that first.
Josh
In my case it was a package in the front seat... Very sensitive
Sent from my LGLS990 using Tapatalk
  • 4 years later...
2020 ZR2 with the same problem.
Dealer states was not able to reproduce/
Can someone please help with a solution?
Please advise.
My best.
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
