New idea for exhaust setup: Catback & Deleted 3rd cat, true 3"
FL335i
I spent some time today looking at all the bolt on cat-backs. 3" Mandrel bent seems to be the norm. What I did notice is most of them, all but corsa do not have a flex pipe. They all rigidly bolt up. Look at the pics, it's clear they have some kind of small diameter pipe and then if expands out to 3". So the Cat-back is 3" mandrel, but whatever it's hooking to, the 3rd cat, is not 3" on the outlet. On the inlet side of the cat the Y pipe looks like 3" all day long where the two banks come together. My plan of attack is get a AFE cat-back and then have a muffler shop cut the 3rd cat out and install a short flex spool like the OEM, but in 3". My thoughts are weld a 3" flange on the Y-pipe upstream of the 3rd cat. And then cut off the few inches of 2.5" or whatever all these cat-backs are starting off with and put a true 3" flange on it. So the idea is put a flex spool between those two flanges for a OEM fitment and vibration. And then we have the stock y pipe coming to the stock 3" and then we flange into the 3" Flex pipe and flange into the 3" cat-back system. That 3rd cat really necks down on the outlet side. Thus far, the AFE system is top of my list. AFE or maybe the Dynomax. Both are simple, 3" and I'm going to cut the connection section off and weld a 3" flange on it anyway... why spend big bucks. This setup should be spot on the money. And no check engine lights would come on.
Flex Pipe: http://www.jegs.com/i/JEGS+Performance+Products/555/30777/10002/-1
Flanges: http://www.jegs.com/i/Hedman/500/21118/10002/-1
OR, for a more stock look these connectors: http://www.jegs.com/i/Flowmaster/389/15930/10002/-1
AFE Cat-back system: http://afepower.com/shop/details_new.php?partno=49-44038-B&filter&menu=gas&engine=5.3L&searchtype=vehicle&make=Chevrolet Truck&model=Silverado&year=2014&engine=5.3L&&brandID=63
And if done properly, will look pretty much stock. :) Stealth is good. Shouldn't be obnoxious loud, will function perfect and not squeak every time the truck goes between 4cyl mode like my mine does. Squeak, squeak,... I hear that valve when I have the windows down. Not cool.
Actually at the merge point of the Stock Y-pipe is 3 1/2" I measured it and whacked the 3rd cat off and bought a 3 1/2 ball connector from Dr.Gas and connected it to the 3 1/2 inch MBRP S5086409 6.2 exhaust on my 5.3. If i wanted to install my stock exhaust to the Y-Pipe it would bolt right back together without the 3rd cat of course. The Dealer Tech saw this and was like Damn... (He didn't notice it) until I showed it to him. You don't need the flex pipe crap no squeaking here.
RT
Check out my truck on you tube its 2013 5.3 chevy extended cab short box. I got 2 3/4 inch cat back straight pipe no 3rd cat and 3.5 inch crime tips on 90s. It sounds like a big old cammed up big block while idleing. My you tube channel is Conky Conky
^07softtail- So I could buy a set of Dr. Gas 3.5" Ball/sockets and then cut the 3rd cat off, weld it right to the 3.5" section of Y pipe and then adapt it to a 3" or 3.5" Exhaust system. I like it. Done deal. just not sure a 3.5" is really needed. Did you lose any low-end torque? The MBRP muffler looks small, figured it's louder than most cat-backs, correct?
That's correct... I figured it would feel soft on the bottom but I can't really tell. I am doing a tune soon and I will see then if it lost any. I also emailed DR Gas and they told me you could use a 3.5" ball end to a 3" flange end so in simple terms that would be your pipe reduction point as long as the angle stays fairly straight. It sounds good to me and will bark when you hit the loud peddle!
RT
I did the 3.5" exhaust with the idea of doing ARH long tube header and Y-pipe so when I do it will bolt up just like a stock system would.
RT
^I'm liking it, but will do the 3" system. Maybe AFE. But I knew there was something goofy going on with that 3rd cat area. Looks like it left a lot on the table. That's the squeeze point in the system.
Ok, on the fence between AFE and magnaflow. AFE's is considerably cheaper. The only difference I think is magnaflow's has a flex section up front. ??? Opinions? Plan is do the cat-back then in the future, delete the 3rd cat. That's as far as I'm going.
You don't need the flex section if you are concerned about that....and as far as the 3rd cat you can drill it out and break it appart to remove the material It's very brittle and can be removed very easy. It took me 15-20 miniutes to drill and dig it out.
RT
^ Hollowing it out is OK with me, but I wonder what size the inlet/outlet on it is. I want a true 3" or 3.5" flange on the Y-pipe and then get it down to true 3" into the cat-back. So I might have to cut off the front small section on the cat-back. They all seem to have small pipe and then flare out to 3".
it's not even 3" it's more like 2 3/4 exiting the cat and at the cat-back connection but the pipe section before it goes into the cat is 3.5". If you want a full 3" you will have to do what we discussed in the earlier post with the ball connector. Trust me I've done all the homework for you! LOL!!!!
RT
  • 3 weeks later...
These trucks also sound very good with just taking off the factory muffler and going 3.5 inch from the 3rd cat back out on 45degree angle and 4.5 inch crome tip.O and FYI if your interest I found away to completey disconnect traction control.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
