Billet Grill
Ok guys to make a long story short my stock grill looks horrible from debris and other stuff.  I am going to put in a billet grill.
Whats the difference between brushed and polished?  I am particularly looking at the stull product
Thanks
This probably wont be the best explaination but I'll try.  Polished is smooth and shiny like chrome and brushed is dull and basically looks like someone sanded it in one direction with light sand paper.  I am partial to brushed myself.
i want something dark so i think brushed would be better?
How does it hold up with rocks and such?
Ryan,
I want a brushed as well for the dark.
With your grill, it should deflect a good bit, but if you take a direct hit with a rock, it will show. But you will look good until you do.
I want a dark grill not a bright chrome one.  The speed grill does look nice but i want something more subtle
kinda pricey but i think it would look awesome
Looks good, just don't know how much room I'd have to move the shell with the brush guard on...Actually Ryan, how do you plan on tackling this?
I am removing the grill guard to do some cleaning (and fix a few rusty spots)
Ryan, you may want to consider painting it w/ some rust proof paint and then a few coats of glossy black.  I ended up doing mine w/ spray on bed-liner which looked great, had a textured look and when it was nice and clean the spray on bedliner had a nice sparkle to it.
I second this idea.  I have a few friends that have coated their brush guards & nerf bars with that stuff.  Holds up awsome...no more rust.   :thumb:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
