Victory Red Silverado - Blacked Out front End
Somewhere I saw a victory red silverado with a blacked out front end. Pondering doing it to mine. Can't find the pics of it to help me decide. anyone know whos that is so i can look at the pics again?
tia
Skippy
Rough Country's Silverado is just like that. Go to their website and look at the 7" lift and that's it
Thats it. Thanks. Not sure if I want to go black or color match to red.
Plastidip for a trial run as its removable.
I want to black out mine as well. How would you go about doing it?
Colormatch it. Black will look like a work truck.
so this:
2014_chevrolet_silverado_1500_lt_victory
or this:
on this truck:
Their blacked out truck looks good. I didn't think it would really but.. it goes together well.
I don't care for the chrome headlight trim on the other one. I dunno why GM is doin that.
  • 4 weeks later...
I am stuck between the two as well.
Thought about the red grille and black plate bumper.
um, because the chrome headlight trim matches the chrome grill the truck comes with?
Body color grill's shells for Black , Red , White , Silver , Ruby - ebay
Yes, but the new 2015 Silverado MIDNIGHT EDITION Z71 looks sweet! I'm going to start looking at part #'s to try and keep the front and rear end all stock.
