Advice for payload mods (bags, etc)
I bought my truck for home renovations and have been doing a lot of hauling (no towing.) The truck sags really, really badly when at max payload and feels squirrelier on the interstate. Not dangerous or anything, but it loses a lot of its composure. It was really apparent this weekend when I hauled pavers and mulch and I almost wished I would have purchased the 2500. Had to make three trips because of weight.
I'd like to at least be able to haul the recommended payload without the rear being 6 inches off the ground, so my first thought was to add bags to the back. I've never used bags or owned a vehicle with bags, so I'm unsure how that works. I've done a lot of work on trucks and cars, but haven't come across bags yet.
So here's my questions for you guys:
Do bags replace the leaf springs or do they help the leaf springs?
What bag kit would you recommend, I looked into the Airlift LoadLifter 5000 Ultimate kit?
Are there any other modifications that would help with payload hauling?
Thanks
  • Replies 33
I have hauled a pallet of grass (3000 pounds +) and mine did OK. Were you hauling more than that?
I was hauling about 2000lbs or right under. I was exaggerating the squat (6 inch from the ground.) 3000 seems like a lot!
If you have a 1500, you are over your payload when hauling 2000lbs.
If I had to guess without looking, your payload is 1200-1600lbs
That would be on the high side.
Load 1: 45 bags of 30lb mulch = 1,350lbs + 150lbs of gear + me 185lbs = 1,685lbs
Load 2: Pavers were 12lbs each x 110 + 10 bags + gear + me = 1955lbs
Load 3: 100 pavers + 15 mulch + gear + mee = 1985lbs
Door label says ~1785lb payload. Moving right around the payload capacity, slightly overloaded on the last two. My question is not how to increase or bypass the legal payload of my truck. My question is how to modify it where it handles max payload better than stock.
Thanks
Bags would be best but leaf helpers also come in cheap and costly. I had hi-jacker air shocks (150 psi but 200 max) and an extra leaf I took off a junkyard truck on the regular cab, as my signature shows...it held up a 7,500lb camper (unsure on tongue weight) but rode like crap when empty.
Assists (1 side of leaf):
http://www.oreillyauto.com/site/c/detail/SPR4/111020.oap?ck=Search_11-1020_-1_-1&keyword=11-1020
Bags:
http://www.airliftcompany.com/shop/88204/
Helpers (both sides of leaf):
http://www.sdtrucksprings.com/hellwig-2515-2wd-silverado-1500-helper-springs-2007-2014
http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=5664
Thanks for the links. From what I understand, adding springs will reduce sag but cause a bad ride. I do a lot of unloaded traveling too, so I'd like to retain the stock unloaded ride. It seems the adjustable bags are the best choice.
I installed the Firestone bags. They were an easy install and they've been working great.
I looked into that kit too, but I couldn't find out if it came with the internal bump stops like the airlift kit.
3000lbs?? Wow I'mpresssed on our 1500s we're u sagging on the ground or was like 2-3inches below stock height?
Riding pretty low, but not on the stops. My 13 could do it too. You can feel it most laterally, like going around a curve. I may have to do it again Friday...if I do I'll snap a pic.
Nice to know it handle this much weight of course I don't have s reason to put that much weight but if I came across where I had to i would have the feel better knowing out trucks can
Got any pics loaded? Also do you have a leveling kit?
And if I tow 3000lbs Im using a trailer lol
Would love to see a pic of 3klbs loaded on our trucks. I think you need bags more than me :)
This got me thinking, I might want some air bags too. I am leveled right now, if i haul anything, I am gonna be nose up.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
