AMP Power Step rattle?
I have a rattle that's driving me nuts.
It's only the driver side step that rattles when hitting any little bump. I've traced it to the left step. When I grab the front edge of the retracted step, I can pull down enough to create a little gap on the up position stop. I believe this is the source.
Anyone else having this?
I did when they were first installed. The installation guys didn't tighten them enough and my driver side was loose. Since I torqued them to spec, not a sound.
Yep you have a loose bolt, nut, or combination Spurshot. Seems like it's pretty common with these steps I personally go ahead and check each but and bolt every other or every 3rd time I wash the truck. Check it by hand that is. And then once every other month I'll take out the ratchet and make sure that it's definitely tight
Mine does it as well. When step on it it sweaks. Just haven't messed with it yet. I have too many projects I'm doing at once.....
I'm sorry I don't know how to post my question.... so I'm going to add it to your post .... my 4wd went out then it snowed and someone turned it on not knowing it was out and it cracked that bowl that sits on top of the transfer case I don't know what it's called I done brought 700 dollars worth of parts from the gmc dealership that are non refundable and still aren't the right parts someone pls help
just go ahead and reach on under and make sure all nuts and bolts are tightened properly. If they need to be tightened then get a ratchet and tighten them all the way, its easy. Only takes you a few minutes
I used loctite on all bolts when I installed and havr not had a sound. Hopefully it's just a bolt and use some thread locker this time.
I'm not convinced my problem is loose bolts. I can pull down and open the the scissor links on the front link. The actuator is near the back on the driver side step.
Watch the AMP research installation video on YouTube and check each step they take when installing. The guys installing may have installed the drivers side motor with the step in the wrong position causing it to not retract fully/lock. If it's not that or a loose bolt it could be a dud set but that's pretty unlikely.
Just had the exact same issue you're having. I'd bet that it's your parking brake block(where one cable changes to two) just bouncing enough to slightly touch the step. In order to remedy this I just bent the wire bracket AMP supplied us with up a little bit and problem solved. I found it by banging upwards with my hand on the underside of the retracted step till I heard the slight rattle, then traced it to that block on the cable.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
