AN Fittings need help
  • Replies 53
The problems is, mine already overcools.
Thanks for the quick reply, That was a concern too so I guess I will buy the one you have. What temp do you usually run at? And do you happen to know what the lowest normal operating temp we should be running at? Thanks again
I run about 50° above ambient temp unloaded on the highway. I am unsure what the temp should be
I run roughly 120 degrees above ambient temperature
Sent from my LG-D800 using Tapatalk
Ok thanks, It sounds like maybe I should think about covering it in the winter and I should make fixing the trans temp gauge a higher priority.
Zip tie cardboard to it in winter.
I don't think you can run a tranny TOO cool - the cooler, the better.
My Silverado 1500 is 100% stock with the HD towing package. Normally runs about 80° to 100° over ambient unloaded, and 100° to 120° towing - will hit the upper end of that on long hills in summer. 215° was the highest I have ever seen on a 93° day pulling 6k lbs up a 12% grade at 45mph for a few miles. Even the engine temp came off 210° and started nudging up. As soon as I crested the hill, the temps all dropped like a rock.
I might want to grab that same cooler you got there at some point. Not sure I want to deal with AN fittings though. I like to keep it simple.
From what I have been reading you need it to get warm enough for the torque converter to lockup and you want it to get warm enough to evaporate any moisture in the trans but other than that the colder the better. I'm not sure what mine gets to because one truck doesn't have the gauge and the other isn't working. I think I read it has to reach 68 f before the converter locks up and if mine is like Chris's and runs 50 f above ambient my converter won't ever lockup on cold days. But I will just cover it in the winter if that is the case. You could always use an adapter to from the AN to the type of fitting you want.
I probablylive in a different climate, but i have not had mine lower than 95° from prolonged operation even at 30°
It gets to below zero here quite a bit but covering it in the winter should let it warm up enough. I also saw some thermostats but the lowest one I can find is 165 f....If I could find one with a little lower temp then that would be ideal I would think.
With coolant, these OBD-II vehicles will throw a light with anything too far below OEM temperature - all emissions related. :rolleyes:
There's no reason to go lower... all you'll notice is it takes longer to warm up. Your pickup knows what temp it likes and will keep it there.
Ambient +90F seems to be the norm for an unloaded trans temp.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
