So my father has the EXACT same truck as me. I drove it today and it is totally a different feel. No squeak, and seems to have a lot better acceleration and not as much transmission and throttle lag. Wtf?
I just noticed one difference between my dads truck and mine. I have the 3.08 rear axle and he has the 3.42. Could that make any sort of huge difference?
With all due respect Patsy G, the dealers aren't helpful at all. I've already refunded my extended warranty because they won't fix anything on my truck unless it's on fire and shooting fireworks into the sky. I've paid out of pocket to fix things they wouldn't. Warranty means nothing.
Hey Kev,
We regret hearing you feel this way and apologize for any negative experience at the dealership. Again, feel free to send us the requested information via private message if you'd like for us to follow up on your behalf. We're happy to assist any way we can.
Sincerely,
Eddie A.
GM Customer Care
I also have the exact same noise. The Dealer will replace your cat back however if it starts making the noise again.....too bad. I think I will try a clamp first. Only issue with the clamp is a possible drone when in V4. And I hate drone.
clamping it will get rid of the squeak, but yeah you'll get a slight drone when cruising in V4 mode. I clamped mine all of this past winter, but recently took the clamp off. Of course the squeak is now back and I was trying to spray some lubricant in there but it doesn't seem to help.
this issue just started for me recently. Didn't hear it at all last summer. The afm will probably go out in high mileage anyway, as with the radio screen, and other "programmed" features. Would it changed mpg or pick up? Or affect anything really?
If clamped
My 2014 GMC Sierra All terrain 5.3 Squeaks. At first I thought it was a vacuum hose or something but this makes more sense.
Ill be contacting my dealership when I return home.
My 6.2 dose the same thing and ONLY does is going from v4 to v8 so is it the flaper or something todo with the AFM ??
Its the Flapper.
ok thanks glad to hear that is all it is
Dealership told me "posible solenoid" but did they attempt to fix it? No.
solenoid to what AFM ???
So I purchased this Siverardo back in April of this year. It now has just over 2k miles on it. This truck had the crossover pipe replaced when I purchased it because I found a crack in the pipe where the factory tooling flattens it.
For what it's worth, I have this "Chirp" as you say, but I hear it as a "Ching" sound also. It happens always when I allow it to coast a bit then hit the accellerator. I also hear a lot of rattles coming from that area mostly on cold start-up and then it dissapates a little.
I brought it to the dealer here in Massachusetts. I gave them a typed paper explaining all my concerns. They printed out a couple of reports and told me it was normal noise.. It's very annoying.
They did take care of the 70mph vibration but these driving sounds and noise are bad also... This dealership has seen me alot, but hey, I just took out a mortgage on a truck and I think the issues should be taking care of.
One thing I also tried, because of my prior experience as an auto mechanic, was having someone hold their hand over the tailpipe with a rag.. You can definately hear leaks up there... Anyone else hear this? I was wondering if this could also be linked to the strange noise I hear when traveling down the road in the left lane, say against a road partition... Strange sounds being bounced back...
Mine just started this a couple months ago. Would greasing the flapper or even partially keeping it open help. A louder exhaust would eliminate the noise I assume?
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 768 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
