So I took my truck in last week it's 2016 all terrain. They tell me they have a fix but it's only available in certain parts of canada but not in b.c. Then he tells me engineers are working on a fix.... So which one is it? How hard could it be to figure this out.
Would installing an aftermarket exhaust fix this? Mine has been doing this bad. My 2015 has 41K on it.
Yes it sure would
  • 2 months later...
I had my exhaust replaced by the dealer, and now it's quiet and the squeak is gone. I had to print out the tsb and show it to them as the first trip in was told it's normal noise.
  • 1 month later...
So after a few months of no noise after having my exhaust replaced my daughter said today "daddy what is that rattle noise?" Sure enough the second you touch the throttle there is a rattle in the exhaust. I clamped the flapper open and the rattle stopped. Is it worth having a new exhaust put on every 3 months?
Mine has started ticking while it v4 mode dealer sated they think it is a exhaust noise has any one else had this problem as what was it
What do you mean by ticking in v4? Mine used to squeak every time it went from 4 to 8. The new one doesn't squeak but rattles under light rpms
Also a little bird told me the flapper was relocated in front of the muffler on the 2017s to eliminate the rattle noise from the flapper.
Mine has always made a squeak when going back to v8 but now when it is in v4 and under a light load it almost sound like a valve rattle or tick it might just be the flapper but I would like to know for sure
So I just got a 2015 silverado with the 5.3 V8 in it.. I have 600 miles on it and have been noticing that whenever I give it a quick little tap of acceleration I hear this squeak noise. A quick little "squeak". I also notice it when I am coming to a stop and then hit the gas again theres this squeak. Also when I am turning and hit the gas I hear it. I do not think I am crazy, and it is not a very loud glass shattering squeak but it is there. Has anyone else had this issue or heard of it? Thanks!!
Mine has been doing this since I bought it. Dealer cant hear it though. I have just gotten used to it.
GM has a bulletin for it. Print it out and hand it to the advisor. That is all I did and they ordered me a new exhaust. Supposedly there was another bulletin in February that theyou redesigned the exhaust to take care of this problem.
Twist valve open, insert bolt as shown, tighten = squeak solved
Mine didn't squeak to begin with lol but it's fixed anyhow ;) a38a7069cbeb4558ef6812bd5410539d.jpg
how's it sound in V4
Where might one find this particular service bulletin?
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
