Hey all, driving home tonight, and the display screen in my 2014 Silverado started acting up. See the video here:
I had noticed about a week ago, when listening to the radio, and displaying the audio tab, the presets disappeared. I figured there was a setting or something that I inadvertently changed, and spent a little time trying to see if I could figure out how to get the back, but never could.
I don't know if that issue is related to the screen blinking, but I figured I would mention it. As you can see from the video, everything seems to work, I turned off the radio when I took the picture, but it was working while blinking. The Nav and phone functions seem to work too.
Anyone seen this?
Looks like a software corruption, you can try resetting it to factory setting if it is in the options (i will have to check where, but there is one, I have seen it)
And go check your version, i think the key combinations is power menu and home pressed at the same time. Look for 0474 for the version somewhere
Anyone seen this?
Hey there,
We certainly understand how frustrating this may seem, and we would be more than happy to bring this to your dealership's attention. Feel free to send us a private message along with your VIN, current mileage, contact information and a preferred dealership. Looking forward to your updates and response!
Patsy G
GM Customer Care
I'm sure GM will fix it just like the fm reception, steering vibration and seat issues. I'm about to get a Ford. This '14 high country 4x4 has been a true disappointment.
  • Haha 1
Well, the system performed normally the next day. Assuming it doesn't start happening again, I'll just wait until I go in for service, which should be in about a month. Perhaps there is a software update...
There was an update back after the 14's first came out, make sure that was done or that they have the newest update installed as it addresses some of these issues.
  • 3 years later...
On 4/26/2015 at 7:53 PM, GMCustomerService said:
Hey there,
Patsy G
GM Customer Care
We are having the same issues with our 2015 Silverado 2500. Can you tell me how to correct this issue with this radio screen glitch?
  • 6 months later...
I have a 2015 GMC Sierra and my screen is doing the same thing and my dash screen changes as well. Is there a fix for this yet
Edited by Duckman077
  • 5 months later...
Hi Folks, Happy Thanksgiving!
Old thread but same problem. My 2015 Silverado has strange screen gremlins and it affects the smaller info screen behind the wheel as well. Switches channels on its own, flickers, etc.
Any solution to this issue? Seems software related but when I asked a dealer they said they doubted that. Frustrating!
Thanks!
  • 3 months later...
Worked on a 2017 Yukon with the Intellilink screen flickering. Found the Human Interface Control Module Bypass Module. RPO Code: K188. It is located just left of the steering column. Had internal connector fretting. I Unplugged and plugged back in the connectors. Remounted the module. Screen acts normal.
The only problem that I've had with mine is the whole unit would randomly/rarely reboot.  And the night before my battery completely died, the entire unit would NOT boot up.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
