Got a call from the dealer, transmission recall 15178
You can tell that everyone's stress level is up with the day to day life events, people are arguing and snipping at each other over silly things, it needs to stop or this forum will turn into something it has not been. Let's start reading and rereading our posts before we hit post and try and keep it civil. This may be the last polite truck forum out there and it would be a shame to ruin it.
I did get carried away abit but was not mad lol
In Canada , recall is not used , The states still do thou ,
We had the 4L80s whine in first gear and went away in second , the fix was to check end play of rear unit , if it had end play replace transmission , pretty cut and dried !!!!
Have a good day !!
Now that is much better [emoji6]
checked already and nothing is coming up. called the dealer back to get some clarification and they said it has to do with gear whine at 2k rpm 20-30 mph.
Won't be till next week but I will update when I get more info and when the truck is in the shop
Hey Hurricanoday,
We apologize for the unexpected concerns involving your Sierra. However, we are happy to hear that the dealership is looking into this further. We look forward to your updates next week and we would be happy to be of any assistance if needed.
Patsy G
GM Customer Care
In case anyone was curious the dealer looked at my truck and confirmed there was an issue. So they are ordering the parts, says they are on back order so I am going to go pick up my truck and bring it back when the parts arrive. They said when I bring it back they will need it for a couple of days so they will be providing me with a loaner. Didn't get into great detail but can update when I see the paperwork
They also installed the new headlights so hopefully that will be an improvement
Hi All, A newbie to gm-trucks. Traded my '12 6.2 LTZ on April 28 on a '15 HC 6.2. Late in day so salesman says they would detail it and I could get it next day.
Said OK that would be fine. Next day got a call and said it needed repairs per campaign (recall) 15178. Something about the transmission and they would order parts.
Bottom line I got it yesterday, May 8th. Message here if your truck needs this recall be prepared to wait a week and a half.
Had a '10 5.3 and the '12 6.2...Zero problems with both. Hope this 8-speed has better results.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
