Engine oil 2014 1500 5.3l
Novass454
Become a member/dealer on Amsoil and you save a ton. That's what I do.
You used all your changes by 14k miles???? Wow wtf. I just had my 2nd at 14k. I change when the dash reads less than 10%
I change it when it gets to around 50-60% 3,000-4,000 miles. I dont like to push my luck. Plus i know one day ill have to work on the engine and i want it to be clean and sludge free. If i ever have to remove something. I maybe wrong but i dont think the gm computer knows when oil is really broke down. Im sure it just goes by mileage and hours.
three of my friends have 2000 model 1500 with the 5.3l, one done an oil change every 3,000 miles and some when the light came on. hes over 400,000 miles with no engine problems only the crank sensor. he used valvoline
2nd friend changed the oil in his once every 1-2 years. He lost his first engine at 130,000 miles. it started with lifter taping. pulled the plug and his oil was so sludge up. you had to take a screw driver to get it out of the drain plug in clumps. it clogged the oil pump it was so thick. Any brand oil
3rd he changed his oil every 5,000-7,000 miles his original engine lasted to around 225,000 miles. dont remember
So you say wtf, If my engine has a failure I will know its not from the lack of maintenance. oil is the most important thing in and engine. its metal on metal, just like amsoil says good for up to 25,000 miles. i wouldnt take the chance and change it every 5,000. I dont plan to trade in, in say 5 or so years, I would just buy a new truck or car and keep this one till the wheels fall off. I feel ripped off every time i trade in.
I just used my last free oil change and I will be doing them from now on. I see that it needs to be dexos1 apporved and 0w20. I have always liked valvoline full synthetic, because after 200,000-300,000 mile when you pull the valve cover or oil pan the engine still looks like new. No sludge or oil build up.
If proper oil change intervals are implements, no sludge should be present regardless of the sticker on the bottle of oil. Wayyyyyyyy too much though is put into what brand of oil to use.
I buy whatever synthetic oil and filter is on sale at autozone and have had zero oil related problems at 10,000 mile oil change intervals.
I had an rsx type s that I ran royal purple in changed the oil one time a year, that sucker was clean as a whistle torn down. My Honda ridgeline was also a 2 time a yr oil change when the computer told me so and again clean as a whistle
I hate to break it to ya, and its certainly your truck and I get it. but these DI engines aren't the engines of old, ill bet at 14k your valves look like a poorly maintained bbq grill unless youre running a catch can. at the shop a few months back I saw the head on a motor with port injection 200k miles nice and clean, saw one of ours with 34K and it looked like a grill never cleaned a day in its life. if GM says follow the oil service life, I am listening to them lol
good luck man, I learned a ton in this thread alone about my oil selections when it comes time
I share your Philosophy 100%.....You know what your talking about in my opinion! Your the type of person I like to buy a vehicle from.
Daniel
The dexos1 approved only thing is not written in stone as mandatory for warranty compliance. GM TSB 13-00-90-001 elaborates on this. A quote from that bulletin......
If you are unable to locate a retailer, then a GF-5 Synthetic grade 0W20 oil that meets the dexos1™ specification, such as Mobil 1™ 0W-20 Advanced Fuel Economy synthetic oil can be used. It meets or exceeds International Lubricant Standardization and Approval Committee (ILSAC) GF-5 requirements.
So, there is no requirement that a dexos1 "approved" oil be the only choice. As long as an oil meets the ILSAC GF-5 spec it is good to go. Interesting thing, the GF-5 spec is tougher regarding ethanol in gas than the dexos1 spec is. See http://www.gf-5.com Considering GM promotes ethanol use, it is strange they would offer a less capable oil spec regarding ethanol. Not that dexos1 is a bad spec, just that it is not the savior of mankind that some would believe. And some that suffer from inflamed paranoia glands over the dexos1 and warranty thing can rest a little easier.
I am a preferred customer of Amsoil. While the "save a ton" thing does seem like it, it is not quite what it seems. The standard pricing is highly inflated so that when someone gets the preferred customer thing and prices drop 25%, they think that they are saving a ton and they are. But it is a slight of hand trick by Amsoil by inflating the price first then bringing it back down to give the impression of saving.
I do use some Amsoil products for special applications, and am not against the products, but I get the bulk of my oils from a local supplier that offers products every bit as good as Amsoil at reasonable pricing and ships it to me for free. Something even Amsoil won't do. Amsoil has been in the lube game since 1972. My main source of oils and greases has been at it slightly longer... since 1839. And was awarded a couple of years ago with an award for being in the top 500 most technological advanced companies in America. They developed the lubes for the Apache Attack Helicopter and the M1 Abrams tank. Schaeffer Oil of St. Louis, MO. So, Amsoil is not taking it in the shorts by any stretch of the imagination with the preferred customer thing. They are making more than enough.
Good products, just not sure Amsoil's pricing is right.
I use what weight the manufacturer calls for and buy the cheapest I can find, always have. We buy oil in bulk to change the oil in our company trucks and we get whatever is cheapest at the time of order. We work our trucks hard and when we get rid of them they are beat all to hell with transmission, transfer case, and front suspension problems but never have engine problems. If you think you will drive your truck for 500K miles then by all means use what makes you feel good but for the average driver the cheapest will do just fine.
My hubby is an Amsoil dealer. We have been running synthetic oil in our vehicles for over 35 years. My last vehicle used 100% synthetic after it was broken in, roughly 6,000 miles. We got 330,000 + miles and 24 years of use before that sucker bit the dust. It was the cooling system that killed it, not the actual engine. I was hoping to keep it even after buying a new one, to use for hauling stuff and doing jobs that you wouldn't want to do with a new vehicle. We fully intended on getting over 500,000 miles out of it.
In 2001 we drove cross-country pulling a trailer. My vehicle had over 180,000 miles on before we even left. We zigged and zagged from California to NY and back. Total mileage for the trip was 8,800 miles in 30 days.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
