Another trip to the track in the 4.3
Gorske
Took my truck up again to the track. This time have a CAI and running e85. Still have the computer cutting back my throttle to as low as 70% during the run but still ran good. Was great weather 57 and no wind. 4wd launch to 2wd manual shifting it. Stock tune pass was back in April 46 out with 93 Octane ran it the same way 4wd launch to 2wd left in drive. Next step getting a pass with 100% throttle the whole pass! Come on 14.99 :)
Stock tune Tuned
on 93 on e85
60ft. 2.28 2.21
1/8 et 10.33 9.84
1/8mph 66.8 70.5
1/4 et 16.19 15.39
1/4mph 84.1 88.8
Still not bad for a 5500lbs 4x4 truck with a V6 in it. :)
3.42 gears and 265/70/17R for tires btw.
Nice. I have to wonder, if the new 4.3 has been turboed/blown yet in a truck. Thats got to be Syclone/Typhoon all over again.
I talked to ProCharger and they said the 5.3 kit would fit on the 4.3 would just need a throttle body adaptor for the smaller throttle body and they said you would have to get your own tune for it. They were more then willing for me to buy the kit and they said they wanted to know how it worked out and blah blah blah. I know I'd love to try it but 5500 is more then I have to put into a new truck lol.
Very good, a tune with E85 knocked almost a half second off. Great improvement!
Quite impressive.
Pretty damn good for that V6, I am very happy with my 4.3L. For $5500 I'd trade my v6 on a v8.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
